cogfounder
What thickness styrene do you recommend me using to make a full length top? I'm hoping to make it strong enough so that WHEN I roll it over it won't crack to pieces. I'll add reinforcements internally as much as possible and try and tie it into the rollcage so it will just be transferring an impact vs. absorbing it...
thanks!
It all depends on how much "to scale" you want to be?
I used .040 on my topper, but to be honest, .060 to .080 would
be better...
(the round tubes I quartered for the door-over-edges were .030,
so were hard to match up to it...)
It kinda depends on how, just as you said, you support its structure.
The truth is, its still PLASTIC, and your going to suffer loss
if you roll it hard! (just like a store bought hard body)
But no more than cracking a lexan shell.........
and this styrene sheet is MUCH MORE flexible than "hard body"
plastic too.......
With THIS type of styrene, your seams/glue joints will break first,
(the sheet styrene you will purchace) is not brittle, like the common hard-bodies, but the joints are the weak points!!
I would go as thick as you can find, because you are still going to have
to sand your "rounds", or your "angles" anyway. (on a RR top)
What you build, if done well, will not be any less strong than a molded
piece, when using the correct glues, but properly!!!
Just remember what I said about "backing" up the seems with CA,
above and beyond the reinforcements. (Crazy glue -welds-)
You would not believe, untill you learn how to do it,
how strong it makes your styrene builds over just using
a "plastic welding" wet glue.
Show and tell me what your trying to join or mate together, (and how)
and Ill give you my best advice.
(even if it turns out better than mine, I would still have the
HONOR of being asked!!!)
"thumbsup""thumbsup""thumbsup""thumbsup""thumbsup"
