Looks great.
Wes
That is a awsome truck! Great job "thumbsup"
the new wheels look so much better!!, have you tested them out yet?
Coming along very nicely. Last scale comp is this Sat at St. Peters, check EPARCC for all the details. I hope you can make it out."thumbsup"
I'd go for the top one. Your interior is right hand drive so it would be odd to mix the two, especially since you've research it and are trying to make it correct.
Just my $0.02
Very nice looking build! I'm also planning on using the Geolanders on my 2nd Rover. Scale question for you, as this body is closer to 1/8.5th, the 1.55's are more like a 13" wheel, which I don't think works quite right. Have you thought about stretching the 1.55 tires onto a 1.9 rim (which gives you a proper scale 16" rim)?
And now that you mention it, the wheels do seem a bit small. I wonder how the fender clearance would be affected with the bigger wheels.
OD won't change
Hmm... Think the 1.55's are too small?
Thank you! I love how your Land Rover came out! How did you mount the rear of the interior to the body? The front has mounts, but the rear doesn't on mine.
The Geolandars look good, but they are a very hard compound (HPI - D compound). I would not recommend using them. HPI does make a softer compound version, but only in 2.2 size. And now that you mention it, the wheels do seem a bit small. I wonder how the fender clearance would be affected with the bigger wheels.
Tires too, but that's just me lol
Thanks! I scratch built everything rear of the front seats, as I built a longer wheelbase 110. Shoe Goo and styrene scraps mostly holds it to the body. And it partially rests of the frame which is completely in line with the body mounts. All flush and tight to the frame.
I'm going for a scale look and not concerned so much with performance. It should be tough to drive in my mind, so if the tires are a little hard (which they are, I've got them already) I'll cut the foams to soften the load.
If you use the same tires (1.55's) and stretch them onto a 1.9 rim, you'll have the same overall diameter, but a more scale rim size.
Seats will blend in nicely with some paint "thumbsup"
Wow, killer D90! Very scale!"thumbsup"
