Mud flaps are GAY
lol but otherwise looks good! Keeping the Traxxas/Axial shafts or going metal? How good does it go with 3s?
Put a bigger pinion in and a smaller spur instead of a new t-case. 15/87 is going to be really slow with the tiny tires and a 2.18:1 reduction after being reduced by an Axial trans too. Use your current transfer case to your advantage.
keep the trans case for sure do exactly what gimp said it will climb like a mule and still have good wheels speed, I am surpised I really like the look better than when it was on 1.9s only thing I would change is the paint, did you see the 5 -1.55 landies for sale in the classifieds they would be perfect for this build.
That sounds good. Now I just need a bigger pinion. "thumbsup"
The Trail Buster tires it originally had were just a little too big for my taste. And the knobby treads rubbed the fender flares a lot. I did see those wheels. I thought about getting the white set, but then I decided to go for a more "stealth" aftermarket look with black steelies. Did you mean the color of the wheels or the body?
I took the D90 for another trip in the "gully" and it does great!
Although, there is a lot of bump steer. Anyone know of a solution for the Gelande chassis? One of those "S"-shaped drag links?
These are on their way...
A different shaped drag link won't change a thing, may give you some clearance if it's hitting on something, but that's it. Bump steer is a geometry issue with the suspension links/setup in regards to the drag link location.
Good idea with the fan. I would only use one if the 1:1's use a mechanical/clutch fan and run on fairly low voltage to make it look right. If they use electric fans, go for both and run at a higher speed "thumbsup"
This is sick ass and also why dont you keep your class 3 JK, it's one of a kind, also why did you go with mud thrashers instead of micky t MTZs
looking good man like the details on the lights what driveshafts are you running that you are waiting for
love the rover and the grille. i need to get lights in my rigs so i stop running into things when im out:lmao:
I took it out for a test and took some pictures. But when I went to review the photos they were gone. Dang smart phone!
Don't you have 3 or 4 nice cameras?
