cbp27
That profile is hard to get right! It looks like you're on track though. Nice work!"thumbsup"
Thanks. It defenitely wasn't easy.
It's been a while since I've worked on the Defender. Tonight I picked it up, dusted it off and knocked out a couple of things.
Finally made the curved pieces for the corners. I used some thin lexan and put a slight curve into it by running it over the edge of my table. Then it got an even thinner veneer sheet to level it with the surrounding pieces.
Earlier I had completely removed the existing gutter. I threw on a new one that finishes the roof off nicely.
I'm converting it to what I think is the "US-spec" model with the brake lights down next to the turn signals and reverse light. The dash has been flipped to left-hand drive but needs some fine tuning. Now I just have to cut out the corner windows and get some styrene strips to make the window trim. Then the body is ready for sanding and a fresh coat of paint!
