Blue Monkey RC
i'll try to get something up later today "thumbsup"
Did I miss another thread?
Check his website they are there.How we looking on those 5mm Stubbies....
Because that site looks exactly like it did a month ago when I ordered it? And then received a long version.....somehow?Check his website they are there.
Lucky guy, still waiting on mine but should be here any day now I'm sure! Did u get the long or stubby?
FYI: the stock axle shafts will not work with the stubby spool and AX30383
Matt I sent you a email regarding this.
Update thank you Matt for your service! A+
here are the pics of the yeti / exo control arms. The first 4 "actual" pictures are a copy of my last working prototype. As a final step i wanted to go ahead and have a set anodized to see if the holes shrank during the anodizing process. The pivot holes are reamed after bending to ensure proper alignment and need to maintain the correct size or the pin will be too sloppy or too tight and not fit. Fyi these are kinda hacked together (made manually). The production control arms will be cnc machined and have a closed bottom to protect your shocks as shown in the last 2 pictures.
i tried to get a good angle so you can see the major ground clearance improvement simply by adding another bend a the top. If the arm was any higher - your mip cvds would be lower than the bottom of the control arms and vulnerable to rock rash.
[/center]
