littletoyboy
MMP
tenshock sc411 3500kv
i just upgraded my scx10 to the HH torquemaster esc with an integy 35t motor and use 3s lipo... with a 12t pinion on the motor and the stock spur gear... it has tons of wheelspeed, enough to get air over just about any obstacle if you punch it hard. and if you have the castlelink cable, there are tons of options for how you want your crawler to perform.. the "holmes hold" drag brake is by far the best on the market if you ask me. your truck stays exactly where you stop it. i plan on getting a handwound hh 35t in the near future.Sorting out a power system for a Dingo build. Looking at a HH combo, TorqueMaster ESC and 35t motor. Is pro worth the extra $ over the expert for the hand-wound attention? What sort of performance could one expect from a 35t on 3S?
what spur/pinion setup you using?Esc - Hobbyking xcar 60a sensored
Motor - Turnigy trackstar 17.5 sensored
Battery - Turnigy Nanotech 5600mah 65c 2s
Is 4S overkill for a 55t with say 60/9 32pitch gearing? Will i be destroying my gears with that much voltage? Or should i stick with 3S on the 55T motor? Esc is BR-XL.
