U4RC Current Class Specs/Rules
Just my .02, I don't care about the tires but would like to see the 2.2 trophy minimum weight get dropped. The 8lb minimum seems high.
Thanks for the input Michael. The reason behind the 8lb. minimum limit in 2.2 Trophy is to keep LIKE rigs running in the same class. If we dropped the limit further (it used to be 8.5lbs) it would make a huge swing weight wise in that class. Meaning we would have 11-12lbs rigs racing against 6-7lb rigs. That makes a possible 40-50%+ difference in rig weights. IMO unfair. We developed the 2.2 Comp class to cover the lighter rigs and keep similar rigs racing together.
I know some people like to win a race by having a huge "RIG" advantage over their competitor. We lean more toward keeping the classes as fair as possible so the "BETTER DRIVER" wins."thumbsup"
K4L is correct in the fact that it can be a challenge to make a "scale" class rig that is below 7 1/2-8lbs RTR. (although it can be done).
I personally had to remove "scale" items to get my rig down closer to the minimum weight limit for the class.
Hope this info helps.
as far as the cut-n-shuts go (I know, the horse is dead), I'd like to give my opinion as a guy looking forward to getting into U4RC style racing since there is a track opening up near me:
If you start allowing C-N-S tires, it's going to get too specialized, too quick, to be competitive or even have fun getting into it. Much like a lot of the complaints about the Supers in crawling. If you make it too complicated, no one new is going to want to do it. the whole point of racing is to try to "work around" the rules anyway, not try to change them to your advantage.
---slamming each other off track, on board paintball action, maybe even some fire, and a tequila shot after every lap. "thumbsup"[/QUOTE]
:lmao:
wow!!! that would a blast for sure.
After checking out the rules, I decided it's time to get a drive for my Wraith. I have the stock interior, no mods to that. What is the typical size of action figure to use for the driver?
WOW! Six classes now, geez, I hope we don't have a night race...lol
We will be there till the next day! haha
Cool, love to see the expansion, will let more people compete in more classes.
Hey guys, I hope this is the right place for this question....
I was told that my knuckles were not allowed to be run on these cars. Can somebody be SPECIFIC and let me know the reason?
Thank you.
Thank you.
Don't quote me on this, but I believe it's because your knuckles are weighted. Which isn't allowed per the rules.
Nothing is said in the rules about knuckles being "weighted" that I can find.
This is the only thing I could find:
"Weights on axle are not allowed"
Hey guys, I hope this is the right place for this question.... I was told that my knuckles were not allowed to be run on these cars. Can somebody be SPECIFIC and let me know the reason? Thank you.
Specific they are not scale. You don't see 1:1 rigs with big brass weights by the knuckles. We also believe they are not need in rock racing. In scale comps and regular comps I can see where you might want them. We have yet to have a track built where that much weight on the front axle is needed. So far I think Glen Helen is the only track that has a steep climb and most of those racers don't even run weighted wheels. I hope this helps you in understanding why we said no to knuckle weights.
I am not talking about my knuckle weights, I am talking about my knuckles.
http://www.rccrawler.com/forum/axles-trannys-t-case/477623-dlux-custom-knuckles-v2.html
I looked at the forum and your website. You yourself call them knuckle weights. I looked at the delrin pictures and on the inside in view there were six nuts on the back. They don't look scale. I understand you have put a lot of time and energy into designing these but the set up is not scale and we try to keep it scale.
Ok, so youre reasoning is because they dont look scale enough? It has nothing to do with how much they do or can weigh?
Yes it is because they don't look scale. If you can show me a 1:1 with something similar to your set up then we would consider changing the rule but for now it doesn't seem scale. Has for the weight has long has the car meets the class requirements we don't care how they get the weight within the rules. For what they do I don't think it would be advantage, but I don't own a set or even tried a set. I really believe it puts the weight in the wrong spot for rock racing U4RC style. I know the Utah Guys have there own style of rock racing so it might work for that.
I dont really think its fair to have to find something similar since I am guessing you could not do the same for your knuckles but I am not sure I want to get into the whole "my stuff looks scale, yours does not" debate. I think we could both agree that everybody has their own version and there will never be good enough for some. However...... I think they look just like the Toyota knuckles, bolts for the arms and all. Sure, you could pick it apart and say that there is a hole or bracket here and there but I could do the same with yours. Bottom line, there is a knuckle that has a round shape, flat tops and bolted on steering arms, just like the ones I make.
