***UPDATE***
UPDATED RULES AS OF MARCH 30, 2014
All classes: MOA are not allowed. Non-scale race-track style vehicles are not allowed. Battery must be chassis mounted, and hidden in a scale fashion. Electric powered vehicles only. No comp, short course, cut n shut, or pin tires allowed. A tire for the U4RC must be a scale looking tire (example: Axial Ripsaws), either a licensed replica, or a non-licensed replica. Rigs not meeting specific class specs will be placed in the fairest class possible at the judge’s discretion. Tech of the cars can happen anytime throughout the day. Heats will be 8 minutes and mains will be 10 minutes.
1.9 Trail: This class is for 1.9” tire clad vehicles that are box stock thru highly modified. Vehicle must be scale in appearance. Rim diameter must not exceed 1.9”at any point. No short course style rims allowed. Vehicles must have (2) solid axles. Weights on axle are not allowed. (Example c-hubs weights or stick on weights) Vehicles must have rail style, tube, or twin vertical plate chassis. This class requires the rig to have a scale body like your typical 1.9 “scale rig or TUFF Truck”. Wheelbase must not exceed 13” and track width must not exceed 10”.
1.9 Comp: This class is for 1.9” tire clad rigs that are highly modified and resemble full size race vehicles. Vehicle must be scale in appearance for rock-race style racing. This class includes rigs running plastic chassis and/or roll cages. Open to any shaft driven, non-moa axle configuration. Independent suspension is allowed. Weights on axle are not allowed. (Example c-hubs weights or stick on weights) Rim diameter must not exceed 1.9” at any point. Short course style rims are not allowed. Rail style, tub style and tube chassis’ are allowed. Wheelbase must not exceed 13” and track width must not exceed 11”. Rear steering is allowed. This is only class that has 8 minutes qualifiers and 8 minute mains. Due to size of batteries.
1.9 Trophy: This is a builder’s class. This class is for 1.9” tire clad Ultra4 style rigs that are highly modified and highly resemble full size rock race vehicles. This class only includes rigs running full metal roll cages or, a metal upper cage attached to a factory skid plate. Meaning no plastic chassis component allowed except skid plate. You can use a factory skid plate, such as a Twinhammer, Wraith, Scx10, or Wreckluse skid. You could also use the metal portion of an Exo Skid, but not any plastic pieces attached to it. Vehicle must be very scale in appearance. Open to shaft driven, non-moa axle configurations. Weights on axle are not allowed. (Example chubs weights or stick on weights) Single or double solid axle and non-factory independent suspensions (aka hand fab) are allowed. Rim diameter must not exceed 1.9” at any point. Short course style rims are not allowed. A tire for the U4RC must be a scale tire, either a licensed replica, or a non-licensed replica. Rail style and tube style chassis’ are allowed. Minimum overall chassis height of 4.5”. Wheelbase must not exceed 13” and track width must not 11”. Batteries cannot be in plain sight. Transmissions cannot be plain sight and wires should be hidden. You must have a driver and /or driver insert and driver must have a helmet. (NO ANIMATED CHARACTERS).
2.2 Comp (LIMITED): This class is for 2.2” tire clad vehicles that are box stock thru slightly modified. Vehicle must be scale in appearance for rock race style racing. This class includes rigs running plastic chassis, roll cages, and twin vertical plate chassis. Open to any shaft driven, non-moa axle configuration. Double solid axle only. Weights on axle are not allowed. (Example c-hubs weights or stick on weights) Short course style rims are not allowed. No Comp, short course, or pin tires allowed. A tire for this class must be a scale tire, either a licensed replica, or a non-licensed replica. It has to look like something you would see on a 1:1 trail, race, or street rig. Wheelbase must not exceed 14.5” and track width must not exceed 13”. Rear steering is allowed. Must have interior either the wraith or driver inserts. We would like to see drivers in the car, but we understand if it is your first race. (No Animated Characters)
2.2 Comp (OPEN): This class is for 2.2” tire clad vehicles that are slightly modified thru heavily modified. Vehicle must be scale in appearance for rock race style racing. This class includes rigs running plastic or metal chassis and/or roll cages. Open to any shaft driven, non-moa axle configuration. Double solid axle and IFS. Short course style rims are allowed only on the IFS. Weights on axle are not allowed. (Example chubs weights) No Comp, short course, or pin tires allowed. A tire for this class must be a scale tire, either a licensed replica, or a non-licensed replica. It has to look like something you would see on a 1:1 trail, race, or street rig. Wheelbase must not exceed 14.5” and track width must not exceed 13”. Rear steering is allowed. Must have interior either the wraith or driver inserts. We would like to see drivers in the car, but we understand if it is your first race. (No animated Character)
2.2 TROPHY:This is a builder’s class. This class is for 2.2” tire clad Ultra4 style rigs that are highly modified and highly resemble full size rock race vehicles. This class only includes rigs running full metal roll cages or, a metal upper cage attached to a factory skid plate. Meaning no plastic chassis component allowed except skid plate. You can use a factory skid plate, such as a Wraith, Scx10, or Wreckluse skid. You could also use the metal portion of an Exo Skid, but not any plastic pieces attached to it. Vehicle must be very scale in appearance. Open to shaft driven, non-moa axle configurations. Weights on axle are not allowed. (Example chubs weights or stick on weights) Single or double solid axle and non-factory independent suspensions (aka hand fab) are allowed. Rim diameter must not exceed 2.2” at any point. Short course style rims are not allowed. No comp, short course, cut n shut, or pin tires allowed. A tire for the U4RC must be a scale tire, either a licensed replica, or a non-licensed replica. Rail style and tube style chassis’ are allowed. Minimum overall chassis height of 4.5”. Wheelbase must not exceed 14.5” and track width must not exceed 12.5”.Batteries cannot be in plain sight. Transmissions cannot be plain sight and wires should be hidden. You must have a driver and /or driver insert and driver must have a helmet. (NO ANIMATED CHARACTERS).
HEAT FORMAT: We will take the top two from round 1. Round 2 we will take the top two. We will do a LCQ the top 2 to get into the final. This will work for 4- 20 cars. This could change if we don’t have enough cars for a class or too many.
TECH: Checking of the car can either been done at sign up, heat race, or after the main. Cars that don’t meet the class requirements will result in a DQ and no points will be rewarded. Tech will be performed by a U4RC official.
TURN MARSHAL: Everyone is asked to turn marshal unless you physically cannot do it. Turn marshaling is physical work and is hard to walk on the track. If you cannot turn marshal let us know at sign up. We also need track Marshals to watch the track to catch people cutting the track. Please when you are turn marshaling don’t be on your phone, taking picture, smoking, and drinking. Put cars back on the track in the tended direction of travel meaning don’t put the car on the track backwards.
