Harvo
Truck is looking great. Is that chassis a 50/50 bias? I'm liking your balance point. Can you take a bodiless pic of your truck from the side? I'd like to see your link angles.
Did you do this because you had to due to your chassis design or did you do it in purpose?
Well, I spent all day trying to get my new sidewinders to work but they beat me! I'm going to meet up with scattman tomorrow and hook them up to a castlelink. If that doesn't work, idk back to the FXR's for now I guess?
Harvo,
At ride height they are almost level but a little up. At full extension they go up to the chassis quite a bit.
So you have more separation at the chassis than the axle?
Looking good Jer....
What is your ride height stubs?
That's an interesting idea that you did on the rear upper mount.
What if I just make the upper links straighter?
Erik... I believe you know much more about this than I do... but mine seems to act different than you describe. Maybe because My links are mounted higher at the chassis end.... but when I'm at the top at the axle, the truck flows and feels loose.
As I move them down at the axle, it climbs much better, but it seems to stiffen or even "lock out" the front end on off camber breakovers. (Lifts tires more). I run about half way down to get the best of both worlds.
Looking from the side, my uppers travel from the chassis down to my mounting position on the axle.
Stubs appears to have his level or even going up from the chassis to the rear mount.
If you move the uppers down the same amount at the chassis and the axle, does the handling change for other reasons or does it stay the same?
Thanks... Upper movement is always tough for me to grasp.
I also had to put the FXR's back in. So I put them in a little cleaner this time. I shortened some of the wires and put them on the battery mount. Much nicer.
Yeah, much nicer and cleaner!
What are you using for your battery mount?
