Super useful thread. Thanks for going to all the trouble.
Glad you like...thanks! "thumbsup"
Heads up to anyone about to build, the pic on step 58 of the instructions is mirrored. Don’t let it twist your brain.
Thanks for reminding me (I forgot to mention that in the last post). Funny thing...my brain was especially when I got to that step because I originally put the c-hubs on the wrong sides. You can imagine the neurological short circuits that ensued. But I got it straightened out and it's all good now.
Time for more buildy stuff. Like suspenders:
The SSD Pro Scale shocks have an aluminum cap with a lip that helps keep the ball in place once mounted:
I like that they are pre-assembled...shock assembly can be a bit tedious (esp. when e-clips make sudden escapes from the work bench, much to Roo's delight). When it comes to filling shocks, I tend toward thicker oil (usually diff fluid) in my shocks to get real dampening. As you might have seen from the first pic, I went with 2K diff fluid here, and I quite liked the feel once they were mounted up:
As with all emulsion style shocks, getting the right oil level is key. Too much oil, and you don't get full compression. Not enough and the shocks will skip when they hit large air pockets. The sweet spot on these seemed to be just enough oil to cover the piston when the shaft was within a couple mm of full compression. Once you figure out the right level on the first one, the rest go quickly.
The side plates and sliders are an interesting design. The side plates are very similar to stock 10.2 plates (minus the integrated receiver box found on the Axial version) and include the same slots to mount sliders for compatibility with aftermarket 10.2 sliders. But SSD has added a lower plate that makes a smoother surface and noticeably stiffens up the whole assembly:
SSD also includes a set of streamlined sliders to finish it off. It's a nice evolution of the stock 10.2 design.
I was a bit curious to see how the tubular battery tray and receiver box mount would work. Here are the mounts:
I'm happy to report that, with the aluminum battery tray installed, the setup is solid as a rock. And about that receiver box...SSD obviously put some effort into the fuel cell design. Here's what you get in the bag:
I like that SSD molded this in 3 different colors (even though most people reading this will go ahead and paint theirs anyway, lol). The fuel cell receiver box includes a nice wide slot for cables:
It looks like it should allow at least 4 wires, maybe more. I'll have to test that when I get back home.
The fuel cell cage mounts to the chassis:
Followed by the fuel cell:
The Trail King includes a set of beefy steel driveshafts:
It's always good practice to mount with the female ends closest to the axle housing. In this case, that's a necessity in front to allow enough clearance between the driveshaft and transmission.
At this point, I was getting tantalizingly close to something that might look like a truck. So I decided to toss on wheels, tires, a front bumper and a body just to see how it looked.
Before I get to a spoiler pic, here are some notes on body mounting. The kit comes with two different sizes of body posts:
They are on the short side, so they won't work with larger bodies or in the back of SUV-style bodies. Fortunately, like most of the Trail King platform, body post mounts in the shock towers are compatible with SCX10/10.2 posts, so you can pick up an Axial body post parts tree if you want to use clips with a Lexan body. Or you can come up with your own clip-less mount (esp. if you're planning to use a hard body).
The rear shock towers are reversible, and SSD has included an extra set of holes in the back of the rails to allow different body and shock mounting positions that accommodate different wheelbases and bodies. Here are a couple of side view pix that show the difference, starting with stock:
Here's what it looks like with shock towers flipped and mounted one hole back:
Note that for this setup, the body post has moved back, but I still get the same shock angle as before. You can also come up with multiple other variations of shock and body mount locations. It's a nice little touch that adds flexibility for different builds.
Now for the spoiler...for shoes, I chose the SSD silver slots with OG Pit Bull 1.9 Rock Beasts and SSD scale hubs. For the bumper, I went with (spoiler alert) SSD's front Bronco winch bumper, all of which looks creat under the Traxxas Bronco body:
And that's the spoiler. This is going to be a Bronco (not black), with a twist or two to come. Next update will be the 3d engine. Thanks for following along!
