Hello everyone update here.
Very picture heavy.
Okay, so i'll just write a large paragraph explaining everything i've done, and then you can check out the pictures of the work in progress and finished progress and other random pictures of the truck poser shots etc...
1st I made a Y harness Timaya with 12gauge wire from the LHS for the winch
2nd made an extension for the winch. so that I could temporarily use the button on the controller for the winch. until I buy a 4 channel tx and rx. probably the traxxis.
3rd Moved the front bumper up and farther forward, this was to stop the front tires from rubbing the bumper on full articulate. This also makes the bumper belong to the front of the jeep.
4th added Novak stickers due to the novak super rooster reversible ESC, found them at LHS
5th fixed broken LEDs
6th fixed skull head on front of grill. looks better.
7th added bungee cord eyes
8th fixed tow ropes with heat shrink
9th added eyes on front bumper, and 2 eyes on chassis in rear.
10th added an interior light, might of said that in previous post, but forgot to take a good picture of it lit up at night
Updated Spec list.
Waterproofed Novak Super rooster reversible ESC
Stock Spur 87t
Axial 27Turn with 21,25 tooth pinion, RC4WD 35turn 15tooth pinion
Hitec 645MG
Waterproofed rx Axial Ax-1 Ar-1 2ch
#8 threaded rod, traxxis rod ends, aluminum tubing 4 link with bent back and traxxis metal balls.
Spike's custom 29 LED system Fog lights, Brake lights (doesn't dim), reverse lights (attatched to esc), Light bar, running turn lights (no blink)
Proline Flat irons 1.9
3racing winch @ 8.4v nimh
Electricfly 3800mah 8.4v nimh
High Energy 4600 mah 8.4v nimh
Steel transmission output upgrade.
2 ounce weights back
1 ounce front/spare
Spike's towropes, bungee cords.
