the servo wasn't strong enough to push that stuff, it was made for 2.2 tires! lol and these aren't the best mud tire out there
i'm in a toss up between 1.9 tsl super swampers, 1.9 mikky thompsons baja claws and those 1.9 iloks and those 1.9 roklox
I was thinking the claws or the iloks because one is 114mm tall which would give the jeep a little bit more "beef" to fill out the rims and wheel wells.
Here I've fixed the wheel base, I stuck the 98mm links in the rear, and I cut the bumper a little so it don't rub the tire. She looks right and perfectly center to the wheel wells. only issue I have is with the bumper, I drilled a hole in the last part of it, I can't put it out any farther, meaning there is no room for the winch, and I also bent the bumper mount upwards from taking jumps with a front end heavy rig. So I will need to replace it with an aluminum one and stop jumping lol
Removed unnecessary weight for rock crawling for now.
After wheelbase was fixed, body was mounted 1/8th of a inch lower, LED wires wrapped a bit better with the esc wires. Removed half inch of flairs in the front and removed part of the flair that hit the bumper when mounting the body, and 1/8th of inch in rear, rounded the flairs and then got it real messy. Took her for a spin in the rain, played in the dirt and crawled around a bit till the battery died.
and of course rear/front flex shot, and single tire flex
feedback is welcome
thanks for looking!
*edit*
wheelbase from wheel hub to wheel hub is 12.8"
and the link to the entire build is here
http://s1123.photobucket.com/albums/l558/thespikeisme/SCX10 4dr Jeep/
