I have a barrage gen2 and a maxstone 10, which is pretty much the same truck as the everest 10 but in green instead of blue. Like ferp420 said, the e10 will walk all over the barrage, probably.... I say probably because stock for stock, the barrage has WAY better tires. Like, WAAAAY better. So out of the box, it might actually be a draw unless you are crawling someplace that the barrage's tires are simply too small for.
That said, simply changing the tires makes dthe e10 a much better truck..
I actualy have the same tires on both of time, pro-line BFG t/a ko2's The only difference is size. 2.2's on the maxstone 10, and 1.9 on the barrage. On both trucks, the tires work really well. I bought them because its what I run on my full size vehicle, but they ended up working better than I thought they would.... The only other mod on either truck is a few ounces of lead in the front tires on the maxtone.. Oh, and the maxstone has 4 wheel steering as well.
So, now the reason I own both. I started with the maxstone 10. Then, last summer I decided to pass it on to my daughter (9 at the time), and get myself something new. I know from past experience trying to get my older daughter into RC that when dad has a super awesome truck and daughter has no hope of keeping up, daughter loses interest.... So I actualy wanted something that would be good, but not as good as the maxstone 10, which meant a scale truck. (A well set up maxstone 10/E10 will walk all over any scale truck out there) As I was deciding what to get, the doomsday barrage went on sale for $150, so that made up my mind.
It works out really well, becuase my daughter, who has very little RC driving skill, can keep up with my barrage pretty well, simply because the maxtone is so much better, it takes very little skill to keep up with a moderatly skilled driver driving a barrage....
Funny thing, when I fist got the maxtone 10, I put on the softest springs ans set it up for maximum flex. When I first got the barrage, I thought the suspension was way too stiff, but after driving it for a while, I put stiffer springs on the maxstone and used fuel tubing on the shocks to limit their travel by about half, and it drives so much better! Torque twist is less noticeable, and for the flex, it used to get stuck because it was TOO flexy, a tire would go down into a space between rocks and get stuck. now in the same place, it just goes over the space between rocks....
Anyway, I like the barrage because its a challenge compared to the maxtone 10, but I would like it better if it were a bit bigger. It can mostly keep up with the scx10.2's except where the wheelbase matters. Its kinda like a 2 door wrangler vs a 4 door, there are places that are super sketchy for the 2 door, where the longer wheelbase of the 4 door makes it easy....
All that said, my next crawler will be a trx4..... I wouldn't buy the barrage at full price....
