Full droop is the way to go with a bone stock e10 for sure the cemter of gravity is so high on the e10 it roles way more than when in droop also the droop stops the majority of the torque twist thicker oil in the shocks help too those 2 mods realy wakes up the e10 i say it just about doubles the performance of the rig right out of the box with out spending a dimeRunning full droop without adding internal springs under the shock piston is not ideal. On hills the rig will unload and can flip it over (or at a minimum take traction away from your uphill wheels and raise your cog). Not sure if just removing the springs is better than the stock setup, probably depends in part on the terrain you are running on.
The next best mod is to wait the front end ether the wheels or the axle when i did mine i mounted tire waights to my front axle and a few on the rear just to help keep the wheels down
You can fine tune it later with suspention mods new shocks new or reworked skid plate maybe a new ax10 chassie these free mods will just improve the rig but to go to the next leval you have to spend some money
Stock tire trimmed and sipped i played around with the pattern a bit but these work reaky well on a hot day any more trimming than this and they suck this is were i found that they work good
This tire was over cut and dident work at all maybe in the sand but that would be about it
