So I did my 2 speed over the weekend, and into Monday. lol
Got into the Trans 3 times. 2 for the 2speed and shifting stuff (removed the guild shaft on the 2nd time and all freed up)>
Flattened down the back side of the shift fork to allow it to go into first fully. My setup fully engaged 2nd, but first was a bit slackalackkin. Removing the "Bump" on the rear side of the shift fork allowed the dogs to fully seat in first gear.
Wihtout the guide shaft, some lube on the dog cog and shaft and the 2 speed shifts very smoothly
Note" These things don't have any synchronization at all. So shifting while at speed and/or on power will tear up the dog geras.
If you must shift while at some speed, let off the throttle first, then shift and slowly give it throttle gain.
Act like you're drying a 72 stick shift that dropped the clutch. lol
Doing that alone, will drastically reduce wear on the dog ears on the shifting cog.
Once all that was done, I didn't get my Reefs Micro horn over the weekend so had to wait for it to get here on Monday.
So that's when I did vid number 3, and dug down and worked the shifting horn mechanism over and modded the Reefs Micro Horn, the servo mount on the tranny, and the plastic shifting mechanism so it worked without putting any side forces on the shift lever as it moved in and out to shift.
Here are the 3 vids. They are all long. Me going over, checking out how things work, giving ideas I see going on. Re assessing those ideas etc. .lol
And a bit of general BSing while doing the vids.
Vid 3 is the Reef's Install and what I needed to do to get it working properly.
didn't get out today to do any testing, but on the bench and in the house it works great. Once outside and under some good load, all should be golden in the 2speed world wit the Reefs Mirco 99 and Mirco Horn, and one smaller Drive shaft pin that has been slightly modified along with the horn.
Looks like I lied
I have 4 vids. Last is still the Reefs vid. lol
First Vid.
https://www.youtube.com/watch?v=-3s6YdkqmyM
Second Vid on 2speed.
https://www.youtube.com/watch?v=z7EQ_ttWP5k
(PS, Didn't get to run, except for a few minutes in the yard. too many stiff shifting issues still.)
Third vid, this is where I yank the guide shaft and get it all working smoothly.
https://www.youtube.com/watch?v=xV0qe9tOIzk
And finally, the 4th vid where I deal with the Reefs setup, horn alignment to shifting lever. Mods to the Reefs Micro Horn and connection piece on shift shaft, and what I had to do with the axle pin so everything flowed well without binding during the shift itself.
https://www.youtube.com/watch?v=wzAlmCDKjIQ
