Unfortunately after 96 hours, 42 hours on 4s and 56 hours on 6s jumping, mud bogging and bashing in water, dirt and gravel, I haven't found a way yet, I hate to admit but I failed to destroy any of the parts I used in this HPI boot covered YXL FCDS modification, the YXL front CDS, HPI boot, bearings and axle housing, albeit scratched, are still intact.
Yet being the operative word, I've only been testing this modification on the YXL I haven't tried it on the CMT Yet, I'm sure the CMT will only take 20 minutes an hour tops, to break this modification on 8s. If there is one thing the CMT is consistent with, is breaking parts it hasn't let me down yet. LOL.
I did apply the 3 recessed bearing mod on the YXL RTR, after its initial bearing failure that ate the stock axle housing's pinion bearing walls, in conjunction with this modification using stock bearings, stock axle housing, stock ring and pinion gears( yeah no helical gears yet ). The CMT has pretty much the same setup with one exception, the differential case, the CMT has none it has an exposed steel differential locker ( mangled the HR Aluminum differential locker last year ).
