FCX18 - K10 - MEGA TRUCK Stance -- +2 Inches width!!!
The 1/18 FMS Toyota Hilux is a totally different chassis and drivetrain than the FCX18 , the wheelbase is only 3 millimeters difference . The FCX24 and FCX18 transmissions are slightly different how the shift servo mounts . The FCX24 shift servo mounts to the chassis , the FCX 18 shift servo is mounted on the trans case.
No kidding? ok well then quite a bit of variance across the models then I guess. It all looks cookie cutter on the computer screen lol.
In an annoying retrograde twist, of course now my FCX8 is back down again, the metal $13 transmission case + steel gears (known for this issue) is no longer finding and staying in LOW GEAR. :(
I am done, don't even feel like opening it up and trying to troubleshoot.... Just got done with a bunch of time in the MN82 brushless rig setup.... and now this.
And I even had the really nice (and expensive $27) brass gear, two-tone red/silver metal gear transmission in hand --- its amazing and smooth and shifts awesomely ---- but I returned it on account of I figured I was good to go with the cheaper metal version, thought I had fixed the issue of not getting/keeping in LOW gear with a shim. Prolly I just need to add a few more. But just ug already, WORK TRUCK WORK!
Will get it going one way or other.........
Got the metal transmission fixed! But first requested a return to Ali.. .I mean... wtf... right?
Well heck they know its a known issue so they just straight up refunded me, no need to return! So I took it all apart determined to fix it right... this time I figured it out, you just smooth the shaft step down from 2.5 mm to 2mm ( I took it down to a taper about 2.25mm) and you open up the hole that the low gear shifter shaft sticks out of on the metal transmission case to 2.5mm -- now the pin can travel further out the holel and then it allows the brass collette that grabs the low gear and engages it -- fully finally!
Back to shifting perfedctly smooth even on the fly!! Happy again.... today is the first time all 5 of my latest builds are up running and fully functional...
I have to say it took a lot of doin'.... now just don't break them lol yeah right!
1/5th-ish SCX ClodBuster crawler (dual 570 motor high torque)
1/6th-ish TRX4-XXL RYFT Rubicon crawler (Vitavon Portals, Brushless AM32, 1700 watt outrunner)
1/11th-ish MN82 MEGA Truck crawler (Portals, Brushless AM32)
1/18-ish WPL C24 Toyota Hilux crawler (all metal everything, portals)
1/18 FCX K10 crawler (WPL Portals, metal transmission, wood flatbed)
Posting in this thread as I just don't see a general thread on the FCX18 K10 micro rig....
Had this rig out today for first time in a long time -- man does it just rip terrain really good --- blows the mind and makes me think how WEAK my big rigs are that this little FCX18 can hit the same terrain pretty nicely.
Just was curious does anyone know where or how to source a long rear drive shaft for this truck? I have been wanting a metal / steel one but I can't even find a stock plastic replacement version.
On this rig I used a TRX4 tail end piece and spliced it together franken style to get a solid and long rear axle mated to the WPL portal axles i'm using. I sourced another FCX18 and want to keep stock axles -- but want to go metal driveshafts.
Seems like wheres the love for backups on this rig --- see all kinds of TRX4M and even FCX LC80 but not the K10. The LC80 is interchangeable mostly, but not the rear driveshaft I don't think, its LONG on this truck. LOL I just need a long rear drive shaft in metal -- Want to go brushless and get some wheelspeed out of this next build so def will need metal driveshafts from trans to axles I would think.
Got bugs worked out of this rig after letting it sit for a bit and picked up a friend for it to chill with, or perhaps cut its teeth against ;)
Both rigs, one brushless, on brushed -- take on the Bean Hill Rock Crawl!!! Spoiler alert --- ZERO BREAKAGE!!!!! for once in my life lol. And I def challenged them both, not much in the way of easy-outs for either of them today, if they were gonna break, so bit it I wasn't backing down this hill!!
Both held their own on stock 2s lipo, and struggled as well at points.... I can't complain overall, right, no breakage!!!!!
Yellow truck - brushed stock 180 - 76x27mm DJC tires on 1.0's (no cut, dual stage, 2 separate foams per tire - soft outer, firm inner)
Black truck - brushless AM32 1212 9pole Outrunner - 72x27mm DJC tires on 1.3's (star cut, single stage soft foam)
Took it to town on this rig again and overhauled the suspension setup back closer to a normal FCX18....
Nixxed the WPL plastic portal axles with metal gears -they just didn't spin smoothly/freely enough and I got tired of the extreme wide-stance, it was just TOO wide and over done looking.
Much happier with it now, might still drop down in tire size but not sure --- I do like how well it crawls with big 76mm DJC mud tires -- super soft and sticky dual stage foams work nice too it seems....... went back to FCX18 axles --- metal housings and steel ring/piniona nd portals --- they come also with much too much binding inside -- or not binding they are smooth, no shim needed, just the grease is too thick and dried out.
Added White Lithium Grease and this makes them spin much easier...
Little Ripper!! Got another K10 and this one I kept closer to looking stock... .
All the metal upgrades though, brushless, on JC9ncepts FLING KINGS!!
Rock Crawling is outstanding for a hard body scale setup. I mean blew me away!!!!
