the beep noise?I'm avoiding Castle ESCs because of the noise
The PWM motor noise.the beep noise?
When/where did he say that?The PWM motor noise.
I won't use them either, for the same reason. Holmes says their engineers just don't care, so fuggem.
I'm not sure if a 540l will fit. Might be too long.I have the Pro 2300 in my rtr. It's a sweet spot for my terrain. As much as I would love to set up a rig to crawl some of that massive and dry desert slab we just don't have that round here. It's more fun to have both the wheel speed and smooth creep.
I am tempted to try that 2800kv axe system Col.Sanders suggested in my kit build. I would like a bit more speed but don't want the Mamba whine.
In reply to a comment on YouTube recently.When/where did he say that?
I honestly don't think Castle has many engineers. I know for sure they only have one tech support guy on staff.
and yet Castle is basically the only ESC on the Holmes website"from castle, no silent escs available. I couldn't get the engineers to do it for me or themselves either. And now castle doesn't really have engineering in the USA."
There is a VFD slipper kit, it is part # VPS10208.Had no idea the Optic had no slipper clutch until I built mine. Was thinking I'd add one, till the entire truck was assembled and I realized there is no room for a slipper because the gear cover is already very close to the servo mount. Boo.
It won't according to a post in a group on FB.I'm not sure if a 540l will fit. Might be too long.
That confirms my theory. It sucks. Robert, who was on this site, was super helpful. This also explains why the Mamba X software was abandoned and hasn't been updated in years.In reply to a comment on YouTube recently.
That really sucks about the missing part and bent shaft. Vanquish should take care of you.Well, my kit is missing a driveshaft yoke.
And the transmission input shaft is slightly curved and binds every 180*. I pulled it all back apart and rolled the input over a perfectly flat glass table. It definitely has a wobble to it. Email sent to Vanquish and I guess I won't be playing with my new truck this weekend.
Also realized the shocks come with the seals already installed, like no wonder so many people complain about these shocks leaking when you drag the threaded shaft through the already in position and slightly compressed seals. Much better to put shaft through the body then put the unrestrained seals into place.
Was very unimpressed with how floppy the knuckles were once bolted to the housing. I found some SSD 10.2 kingpin bushings that fit the knuckle bores much better than the shouldered bolts included. Then put .2mm worth of 4x6mm shim between the knuckle and housing at each pivot point. Mucho better now.
Overall though I'm very impressed with the design and fitment of this truck and am very much looking forward to putting some hours on it.
Huh? Castle makes their own ESCs.and yet Castle is basically the only ESC on the Holmes website
How much longer than the 2 in 1 is it? That's a long-ass motor.It won't according to a post in a group on FB.
Yes you are correct. But Holmes sells castle ESCs on his website and he currently doesn’t offer an esc that is equivalent to any castle ESC unless I’m missing what he offers.Huh? Castle makes their own ESCs.
For 1/10 scale he offers one esc that isn't even water/element proof, only 4s up to 2700kv, but at a decent price.Holmes offers both the Crawlmaster HV Brushless Crawler ESC and theCrawlMaster Mini v3 Rock Crawler ESC.
You can program castle throttle curves, hill hold brake and crawler setting which eliminates the double brake tap to get you in reverse.they are both more advanced in their way than Castle ESCs, but are specifically aimed at crawlers - not bashers or go-fast rigs.
Holmes used to have a close relationship with Castle. The early Holmes ESCs were like Castle ESCs, but with different firmware from what I remember.Yes you are correct. But Holmes sells castle ESCs on his website and he currently doesn’t offer an esc that is equivalent to any castle ESC unless I’m missing what he offers.
No idea. This is the photo posted in the FB group:How much longer than the 2 in 1 is it? That's a long-ass motor.
Can't believe neither Holmes nor Castle have chosen to come out with a silent 2 in 1 to compete with Hobbywing.
Or even better, how about A dead-quiet 2800kv Puller Pro. Next level stuff.
It never ceases to amaze me how few companies seem to get their shocks right. I do really like the 80mm VP shocks, but yeah. They have leaked for me at about a 50% rate. Likely even higher. Seems to work for the rigs tho.
He's working on it. Until then I'm a total convert to the Fusions, unbelievably good for the money.The only thing he hasn't done is a combo motor ESC like Hobbywing - but his stuff is aimed more at competition crawlers that want the ability to pick exactly what motor type and KV rating they want to pair with the ESC.
Yup, looks too long
