Cycleeric
2 down and 2 to go
A couple of jato rod ends will fix thatI had the same issues with the WB being short with the T1E links in the front and back, it measured 12"wb with 3 1/2in shocks and 4"inch shocks
Try putting a 1/8 inch spacer on the screw for the rod end at the axle. It pushes the whole chassis and all forward. I think it is made that way so you put a spacer in. That way if you get told the wheelbase is to long just take the spacer out no cutting rod ends.I had the same issues with the WB being short with the T1E links in the front and back, it measured 12"wb with 3 1/2in shocks and 4"inch shocks
Found and ordered all new gears. TCS had them all in-stock "thumbsup"
As soon as they're here they will be drilled and the building will really begin
