I've been huffing Tamiya Lacquer Paints, Isopropyl Alcohol and brush cleaner the past few days adding details to this rig.
I bought Tamiya LP-48 Sparkling Silver and then LP-52 Clear Red and LP-68 Clear Blue to try to replicate an anodized aluminum finish for the hose fittings. Why can't anybody make a silver that doesn't separate during painting? I have never found a silver that isn't constantly streaky or fighting to separate. This paint included. This is about as good as my lackluster paint skills get, but it looks good from far away. The Vanquish logo is also painted silver and then coated in clear red. It looks wet, but is completely dry.
Oh and Vanquish includes one of their awesome, red anodized caps for the fuel cell!
My plan was to coat the Power Tank (not a fire extinguisher) in silver and then coat it in blue for the anodized aluminum look, which is a color they offer, but after finding that the silver is streaky AF and painting clear over it with a brush isn't as easy as it seemed in my dim bulb, I decided to paint it with LP-40 Metallic Black instead. I wanted to do the fuel cell in this color as well, but again the paint was more of a pain than I expected so I'm not doing that. Really, these components should have been spray painted I guess. The valve is painted silver and the knob got clear red over it. You can really see the uneven lines up close in the photos, but not from arm's length.
Overall, it doesn't look too bad from far away, but I'm not looking forward to painting the interior.
I took time painting the radiator silver and you can barely see it. Doh! I also think the manual is wrong at the step showing installation of the radiator. You can't use these holes. The radiator is too wide. You have to use the holes above the ones shown.
Up next is wheels and tars! My favorite!
The Trepadors seem to be the go-to tire for this rig because they are slightly larger in diameter than the average 1.9 XL tire. And I mean slightly. This is the 4.9" / 124mm Trepador on the left vs a 4.75" / 121mm KM3 on the right.
I mounted one Trepador to the TSS Stockerz wheels to observe the clearance at full steering lock. Sadly, these wheels do not even fit over the knuckle weights!
It's a sign of the age of these wheels as knuckle weights weren't a thing or at least not a big thing back then. We still put lead wheel balancing weights on the RC wheels.
Earlier in the night, I went on a scavenger hunt in my house and attached garage. My order history on the Vanquish website showed that I ordered a pair of 1.9 Machete V2 wheels. I wondered why I would only order two wheels. So my plan was to find the 2 and order 2 more. Well low and behold, I found these in my garage. Four brand new Proline 1.9 KM3 tires mounted to four brand new Vanquish 1.9 Machete v2 wheels! Reminiscing in my dim bulb, I believe I got two of the Machetes on a deep sale since that's all that were in stock and then I decided to order the other two directly from Vanquish.
These beauties will have to suffice. I love these wheels. I just wish Vanquish would stop being stubborn and offer real clear anodizing instead of this matte finish!
Mmm! Me likey!
I installed a Fanquish hub which is close to a.350 SLW hub and these tires rub the lower links at full steering lock. So I have to either order high clearance links and turn them for steering clearance or order .475 SLW hubs.
