I was very happy to receive the new, aluminum bellcrank from Losi. Very good customer service as I've said before. Here you can see the bent part on the left versus the new one on the right.
New parts on the left and old assembly on the right.
During assembly of the replacement bellcrank I noticed one of the hats would not fit into the right side part of the bellcrank. What I did was to let my impatience get the best of me and against my better judgement I forced the hat into the bellcrank using a screw and nut. It went in easily that way so I thought the hat would free up. It did not. The hat is pressed into the bellcrank and it does not move. Because of this I couldn't tighten that side of the bellcrank down completely or it locked up. So I loosened that screw just enough to the point where it allows everything to move freely. It screws into a nylon lock nut so it should be OK. I have to say I'm very disappointed in the low quality of this Losi bellcrank. The first one bent like Integy Chinesium and this next one wasn't even made properly. Alas, I installed it because I wanted to get this beast back together.
SLW hubs suck for many reasons (as many as there are good reasons IMO) and the recess for the nut just didn't work for the Rock Rey. The axle and nut are much larger than typical 1/10th scale RCs so it just doesn't fit. That coupled with the fact that I hate black wheels, despite the Hutchinsons being so, so sexy, made me get new wheels for this build. SSD 2.2" Rock Racer wheels. I wasn't sure if I'd like the silver rather than raw aluminum finish, but in person they look great. I'm a fan!
The center/inner ring is Delrin which is an interesting choice all by itself and it also has tabs on in to which notches in the front half of the wheel must fit into. I'm curious as to why SSD chose to do this. I'm sure there's a reason.
They sure be sexy though, yo! :mrgreen:
I also went with these wheels because of the open design. I thought they'd look nice and allow you to see the scale brake rotor and disc. I think it looks schmexy!
And here are some shots just because.
Sweet wheels and a nice pairing with the Rock Beasts! I’ve always had great luck with SSD.
Sent from my iPhone using Tapatalk Pro
