I edited your quote to make it correct. It's a great ESC regardless of price. There are more expensive ESCs that suck in comparison IMO.Well I've gotten a couple runs with it so far and it's great
What is the PWM frequency range? And how does changing it affect what happens when you pull the trigger?
I believe it's Pulse Width Modulation, as far as what it does, that's an explanation I'll leave for an electrical engineer.
PWM Frequency
Another item to consider when setting up an ESC is the motor PWM (Pulse Width Modulation) frequency. The short explanation of PWM is how much power it sends to the motor with each pulse (how long the window is open for). The higher the PWM frequency, the hotter the ESC usually gets. A good way to calculate a starting PWM is to use the following calculation:
KV x V x Poles/20=PWM
Scorpion 4025-550 on 12S example:
550x44.4x10/20=12210
OK, I just pulled the trigger on this. It and an RC4WD 35t will be replacing my Tekin RS Gen 2/21.5 combo in my SCX10 II.
This will be my first non-Tekin ESC purchase since like 2009.
Well I've gotten a couple runs with it so far and it's great for the price, I'm using it with a Holmes 13T Crawlmaster Expert in my SCX10.2. I will probably get another for the 1.9 Wraith build as well. I really like the small footprint and on-the-go programming though.
I just got one for the MST-CMX I'm finishing up.
I have two Venom 5000 Mah 20C 3S batteries that I can't use in any of my other cars. They all need 35C or higher.
Will this esc be ok with a 20C 3S battery?
Batteries don't "pull" anything. They supply.
I'm running this in a mostly stock SCX10.2 kit (35t Boost motor, 1080 ESC, 4200 2s, King shocks, PL TSLs on RC4wd steelies, and that's pretty much it), but...
The LVC cuts in too soon. Sure, I'm getting 90+ minutes of runtime, but I'm putting 2900mah into the battery after it hits LVC, and it's at 7.2v.
I'm seriously considering an FXR (or probably going to a CC Mamba X and one of the new sensored motors is more likely) just so I can set the LVC lower.
I just ordered 2 of the HW wp1080 esc's. it seems that everyone on here that has them loves them. i was looking at the HH trailmaster BLE PRO and i just couldnt make myself hit the checkout button. i found these and decided to give them a go. hopefully everyone is still pleased with theirs?
I doubt it unless they have a universal one that will work with this ESC. That's probably not going to happen though.Wifi module?
