I'm guessing you didn't read the instructions and calibrate it properly. Do that. Then come back to this thread a happy person. :mrgreen:Installed my 1080 in my new tf2 lwb build tonight and out of the box I had very little power forward but 100% in reverse. Quickly glancing through settings, I couldn't find a fix. I reversed my motor wires as a quick fix. Has anyone else ran into this?
I replied to your PM. I'm not sure if you got it because Tapatalk said my messages were full.Installed my 1080 in my new tf2 lwb build tonight and out of the box I had very little power forward but 100% in reverse. Quickly glancing through settings, I couldn't find a fix. I reversed my motor wires as a quick fix. Has anyone else ran into this?
So the rated 3A in-built BEC is more than capable of pushing a 25kg servo no probs then. No performance difference running it straight to ESC over a dedicated BEC?
I have one of these on the way are you guys running a bec or not?
Before calibrating this or any HobbyWing ESC you might have to set your transmitter's throttle channel to "Reverse". The manual states that's for Futaba radios only, but that hasn't always been true in my experience. You can try that.
If that still doesn't work you might have a motor with timing. Which motor are you running?
Then it might be defective. Have you tried it with a different motor and receiver?I dont recall if I ever responded to your message or not. I now I have two trail finders, both running an HW1080. The second 1080, I have still not been able to get it to go through the proper calibration, following the steps to a T.
I am running an axial 35T motor on this particular ESC. I have reversed the channel as specified also.
Nope.
What servo are you running?
Savox 1210sg
Holmes HV500, Savox 1231 and Spektrum S6280
Good indication that it can handle a decent servo: I run a 7955TG @6V and some lights. Even when the servo is in a bind, the lights don't flicker. Which means that voltage is stable, which means the BEC is most likely just fine with the load!
Didn't try upping the voltage yet, though.
FX-R is definitely smaller.anybody have a side by side picture of the 1080 next to an Fx-R?
