Ok, last update today. Probably the last until the weather gets warmer so that I can send the Knightrunner body to the paint shop (aka
utdoors).
The Knightrunner body is cutout, trimmed and mounted. Everything lined up great and the body fits this GK chassis very good.
The rear shocks tuck in nicely inside the cab where the rear seats will be. Since the shocks are now located inside of the cab, I may in the future put the Knight Customs full drop bed in. I did buy the file and tried to print it, but I am having problems get the print to finish without having a bed full of spider web filament. Probably my fault and I need to figure out how to fix it.
Not that I wanted to, but I had to trim half of the fender flares so that the tires would not rub when the suspension was cycled and the front tires turned. I did add a 5mm spacer to the rear shock shafts and a 10mm spacer to the front shock shafts to limit the travel so that when suspension is bottomed out, the tires will stop just before hitting the bottom of the fender flares. Since I'm using the GKS trailing arms and the Knight Customs IFS lowering kit, I still have more than enough flex on all four corners. I forgot to snap a pic in a flex position, so I get one and post it later.
The next 2 pics show how the rear body post are attached. I think this will work out very well in supporting the rear of the body.
And the last 2 pics show off the wheels and tires I have chosen for this rig. The wheels are the common cheap Amazon wheels wrapped in the Pro-Line Class 1 BFG KM3's. I've had these set of tires for about 3 years now and they have finally found a home. I think they look great on these wheels and they go well with this Tacoma body.
Almost forgot to mention that I have also installed a set of stainless steel rotor/weights behind each wheel. I found these on Amazon. They have a decent amount of weight to them.
I picked up a few packs of the SSD scale hardware to replace the hex head screws on the beadlock. I still need to order a set of SSD scale acorn bolts for the lug bolts to finish the look.
More to come as I tinker with the build and wait for better painting weather.
