Long time no update! I've been busy wrenching and painting...more like screwing up paint, but that's typical if you know anything about my painting skillz. Now let's pickup some speed on this thread.
I hate stupid packaging. The Tekin BXR was held to the cardboard box with booger glue. Usually that stuff comes right off of the product. This shit would not. I fought and fought and still couldn't get all of it off - even with alcohol. Good packaging doesn't have to be aggravating. Minor complaint. It's Tekin so I know the ESC will be worth it.
Once you install the axles to the chassis it becomes clear why the Panhard bar is so spindly. It barely clears up front. But this truck does let you fully compress both shocks at the same without any interference up front. Nicely done, Axial. I did adjust the ends on this link so that it couldn't move backwards and interfere with the fake oil pan. That oil pan interferes with the servo mounting and the Panhard bar and it just doesn't need to be there at all. I think the servo mount is going to be a popular upgrade if its done right. That will help with making room for a beefier Panhard bar as well as allowing a bigger selection of servos without the need to modify it.
You also realize the rear drive shaft is too short. At full compression of the rear suspension, you still have about 1/4" of space. I don't know if this is going to be a problematic driveshaft that pops out, but it's certainly something to watch.
The drive hexes are held on by a somewhat small 2mm pin with only a 1.5mm hex head. Those that like crazy power may snap these pins. It's another area to watch.
Axial does include the spacers to remove some slop around the axle shafts though so that's good. I'm a big fan of these spacers because I hate the unnecessary slop.
Then I went onto installing the rest of the parts on the chassis.
I stripped this screw that attaches the front shock tower brace because of the martensite plastic.
Here you can see how it's going to be impossible to easily remove the upper links when the chassis fully assembled.
The sliders are a two-piece design. Interesting that these were made in two pieces, but the assembled part is nice and compact and sturdy.
The floorboards look like a throwback to the SCX10 II - not a good thing IMO. All these support ridges on the bottom are snag points. I will definitely be doing something to fix this.
Also, the slider doesn't match up to the floorboard. Do you see the gap between the two parts? I just have to ask why this was done. It doesn't make any sense to me. This gap is more places for sticks and leaves to get caught. I wish the slider butted right up against the floorboard.
Unlike the sliders, the bumpers tuck in all the way - awesome! Some bumpers of the past wouldn't let you tuck them all the way in unless you drilled another hole for the pin screw. That's not necessary here. Great, little touch!
The inner fenders are a very welcome addition. They are made of thinner plastic and light weight enough for most scale guys to keep them attached. They aren't as light as Lexan, but they are much sturdier so there's a trade off.
The inner fenders have spots for rock lights ala Traxxas. But, unlike Traxxas, Axial doesn't include block-off plates which is a fail IMO. Inner fenders with holes are much less effective.
I designed some blockoff plates if you are interested. Your design idea may vary.
https://www.thingiverse.com/thing:4249467
