8-454's Numero dos! My take on the Sucker Punch
8-454
Displacement
Well I didn't really plan on building another sportsman rig just yet, hence the #2, but I got the opportunity to build The new 5th Dimension Sucker punch and put my foot in my mouth when I mentioned bringing it to Nats......running:shock:.
So I'll do my best to keep everything updated as I've never been real good at maintaining build threads.
The run down of the goods I got so far:
-Sucker Punch chassis
-Negative Space wheels
-Ti links
-Narrowed AR60's
-Wraith trans(its all I got)
-SCX shocks, mini springs
-7950
And some pics:
Chassis and some super cool wheels:mrgreen:
More pics.
Narrowed AR60's with
-OD/UD gears
-Rowdy Racing top mounts
-Wraith knuckles
-CDW Chump levers
-Modded D-lux knuckle weights
Sweet little pieces from Rowdys shop!
And some more knuckle weights just in case its too light of a truck:mrgreen:.
Trans installed. Check.
Looks like there's just enough room to run the factory dig for the pro class:ror:.
:shock: well if you need any thing let me know. I got stuff :mrgreen:
Yeah the threads take so much time: you should be fine though.
The truck should turn out pretty light too. I just finished installing the electronics in mine, slapped a 450 in and threw some rovers on blitz wheels on top and it was at 3pbs 12oz. That's still minus a body but pretty much a runner
Sweet parts list sir! I'm very much looking forward to seeing this come together!
Thanks. Me too!
It's not too bad.
So far it seems like it'll be a light weight. If its heavier than my current S-truck @4lbs, I'll definitely be hunting for the hidden weight.
Whats the motor plate you got in there? Is that an eMachine specialty?
Im sure you'll do just fine getting here going & going well. Look forward to seeing em all crawlin the AZ rocks in a few short weeks.
Thanks for all that you've done for The 5th Dimension E!
J.D.
It's an axial heavy duty motor plate.
Yep.
J.D.
Its definitely going to be neat seeing more than one in AZ this time.
No problemo man! I'm glad to help out where I can."thumbsup"
Got a little more done today. I was able to get some lower links worked out. Rear uppers are temporary, but they get the pinion close to where I want it. The front uppers will have to wait until I figure out a servo mount.
Blurry stance shot
And some closer ones
