Like i replied, it was answered by Tony who knows his Sheat but...
I would like to see the progress build on your large scale crawler. I like big scale builds.
For price of omission here is your list
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w
unctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]-->
Helios RC Conversion Kit (Color of choice)
AX31044 Rear Axle Housing Yeti XL
AX31259 Front Axle Stub 16 x 39 mm (17 mm Hub) - (Qty 2)
AX31089 CVD Dogbone 11x123mm - (Qty 2)
AX31017 Yeti XL Steering Knuckle Set
AX31046 Front Pivot Pin - (Qty 2)
AXA183 M3 x 6 mm Set Screw (Qty
4) or AX31204 M3 x 6 mm (10pcs)
AX31289 [FONT="]Shim 8x10x0.3mm (Qty 8)[/FONT]
AXA1243 Bearing 15 x 21 x 4 mm (Qty 2)
AXA1225 Bearing 8 x 16 x 5 mm (Qty 2)
<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
