cmbscx10
Small Update having had a few hours to "Play".
Chassis plate made. I ordered longer hardware but won't be here until next week. I am not happy with the chassis cuts i made but i learned enough on what Not to do that if i had to do it again it would be different an much better. With the bottom plate and two top plates it is just as solid as if it was one piece. The pictures are misleading. It is actually square as square can be
Saw this on a 1:1 Cherokee a few years ago and decided to do my Tie and Drag link using Hex rod.
The Driveshaft pins are longer than the ID of the Axle tube so i need to shave those down a little bit. Once i get the Drive shafts in i will cut the Hex rod to length, finish that side and do the Tie Rod.
