MaX-D
Crawling?:shock::shock: I have a 3500 mah 120C battery and get like 40 minutes out of it....max.
Sent from my LM-G710VM using Tapatalk
Crawling?
Me too...:shock:I could crawl for a couple hours on that battery easy. I think something's wrong... :shock:
Well ...maybe not strict crawling... more rock bouncing I would say.I usually get 60 to 90 minutes on a 2200 mah pack doing a mix of trailing and crawling.
I would definitely like to know how that 16T motor goes for you, I went with a 13T Crawlmaster and am finding it to be too fast. I'm changing motors for sure, just not settled yet on with what.
Well ...maybe not strict crawling... more rock bouncing I would say.![]()
Let us know how it works!
Mostly crawling but a lot of full throttle blips and the occasional jump and I'm getting a bit more than an hour out of 1000 mah 3s packs.
Brushless is rather efficient though so the mamba x and 2300 roc make the juice last.
Lets not derail this awesome thread here;-)
:lmao:"thumbsup"![]()
I'm still mystified by this sorcery.
This truck perfectly fills the desire I had for a more performance based truck without venturing into the shafty comp crawler realm.
Any word yet on how the shims are working? Is the problem resolved? Is the problem still present? In either case, any new problems?Yes, I did stick another shim on the other side of the gear. Forgot about that part.
I think the shims at the end of the idler shaft would help either way. The idler may float over and make light contact with the gear cover but it is no longer being forcefully pressed into the gear case.
Literally what we hoped to hear...glad you're enjoying it and that last bit of sorcery :shock:
Glad to see some feedback on the magnum motor, is that a torque master or crawl master magnum? I am on the fence and about to go for it for my Capra.
Working fantastic. No more idler gear rubbing and much smoother than initial assembly.
Great thread. Entertaining and informative!
Thanks. Shims ordered...plus a few other "goodies".
I'll have to try that. So what was the outer shim that you used?
I agree that I wish Axial much success with the Capra. I really like the first taste of Axial under Horizon!
Oh and that sorcery GIF is awesome! Glad you got that on video.
It's been far to long since we've seen an update on your new tube buggy crawler thing. So either you haven't been playing with it, or you've been too busy playing with it to update this thread.
As a fellow toy truck addict, i am looking for reasons not to add a Capra to the fleet. All i can come up with is a slight lack of total gear reduction, which doesn't seem like enough to exclude it. Would you perhaps have anything to add to this list and thereby save me from myself?
