if i may ask What did you do to mount the motor ? Mamba Micro mount holes are smaller than the stock Yeti Jr mount allows for
Mamba micro X bolts right up... better check again. Some of the holes are spaced wide.
Been running this battery tray for a couple weeks or so now and I'm really happy with it. It's the 3D printed version that's available on eBay right now. It's really well designed and fits extremely well into the Jr. chassis. You swap a couple screws, remove the leftover parts, very easy install. For the price, I can highly recommend one of these to anyone. I'm still running my little Hitec servo with good results but it's nice to know that if it breaks I can easily upgrade to a full size servo without issue. It also incorporates front fender wells and a nice little tray for the receiver. Handling has also improved due to the lower CG of the battery and climbing is better because of the more central weight bias. All in all, a very well thought out and nicely designed piece for less than $30 shipped. Get one while you can.
How about a steel center doggone? For at part to break on mine.
There is one unless you are talking about the front center shaft.
GPM - Steel #45 77mm Dogbone for Axial Yeti JR (MYT177S-BK) | eBay
There are a few 1/18 crawlers. But they're not without their issues either. The only one I can think of off hand that's reportedly good out of the box is the Proline Ambush.
The Ambush is 1/24 micro. I got plenty of Losi MCRC and a Sumo axle micros. I really like the mini size. A little more durable and capable
