So, a while into the discussions and with a few parts on their way from the US, I thought it might be worth a post listing what I (think I) have settled on so far. Thanks a lot for helping me out!
Motor and ESC, I intend to run it on 3S
Tekin PRO4 Heavy-Duty Brushless 2-3S 3000kV Motor, 145$ with a
Castle Creations Mamba X Sensored 25.2V WP ESC, 145$
High speed, high torque and more efficient than the ROC412, if I got it right. Check out
this thread for an interesting discussion. If DavidH turns out to be very, very satisfied with the ROC412 he's getting I might reconsider.
Steering servo
Savox 1210SG
Waterproof, probably strong enough and good price. 80$
Or maybe a
Savox 1270TG, 84$, not waterproof but "water resistant". Stronger than the 1210SG.
Xpert 7701, 99$, waterproof IP67, 380 oz-in @ 7,4V; 485 @8,4
Radio and receiver
FlySky GT3B, I have one already and am very happy with it. Since the included receiver only is rated for 6V (thanks Magic_Yeti), I'll get a
Futuba R203GF receiver, that handles 7,4V
Maybe a
RX-bypass-adapter, if I install a BEC.
Servo for 2-speed transmission
Savox 0231MG, 37$
Waterproof, strong enough and good price
Aluminum parts from STRC.
Steering bellcrank set, 42$, to tighten up steering a bit
Front skid plate, 18$
Front caster block, 21$
Steering knuckles, 27$
Front shock tower, 20$
Rear upper shock mount plate, 7$
Axial aluminum parts (because these particular parts are (were, due to mistake from tower hobbies) cheaper than STRC)
Machined Adjustable Motor, 30$
Servo horn 25T, 14$
Rear end stuff
MIP X-Duty Rear C-Drive Kit, 34$
SSD wide rear axle, 110$
SSD rear trailing arms, 35$, because as someone said, the rod ends defines a break point and they are cheap to replace. Therefore not Vanquish.
SSD Titanium rear upper links, 18$
SSD rod ends, 4$, goes in my pocket
Wheels and tires - please tell me if this is not OK, since I find this very confusing. Are the wheels and tires compatible?
ProLineDenali 2.2", 66$ (for four wheels). I'll probably go for these and save me some money compared to SSD or Vanquish.
Pro-Line BFGoodrich Baja T/A KR2 2.2" G8 Rock Terrain Truck Tires, 60$
ProLine single stage foams, 28$. Might as well go ProLine all the way. Since I think I'll bash more than crawl single stage should be the way to go, right? I'm afraid I'll roll over a lot more with double stage.
Gears, bits and pieces
Axial 2-speed transmission, 95$. For more power and control at low speeds. I think I'll wait with the 2-gear until I see how the Pro4 HD performs at low speeds. Axial instead of SSD, since it's all inclusive, as DavidH pointed out.
Stainless steel screws from RC Schrauben, ~45$.
SSD HD rear axle shafts, 25$. Maybe. If I am on a spending spree.
That's about it. Maybe a 56T spur gear too. And maybe a vinyl sheet from
Freqeskins for a killer look. While I'm at it, I'd like to name the project "Snowman". So that I later can get a Bomber that I'll call Crake.
