mikemcE
So for 30.00 you get a weak metal geared servo
Hang up and Drive
Hang up and Drive
But 69$ isn't really a cheap hotness8) at that range i would go with a savöx 1210sg.Seen these today....haven't tried them but others have and are at an excellent price point for the specs....
https://www.instagram.com/p/BZYwur0nxR8/?taken-by=reefs_rc
They look solid!
Yep i looked back at this thread yesterday. Even after re-reading it i did the exact same thing i always do. Ordered a solar to use as a steering serve. Which i will use until i am ready to start the upgrade process. At which time the solar become a servo winch and I install the reliable promodeler as me steering.Timely thread, as my stock (E10) servo laid down on me yesterday. I ordered the Power HD LF-20MG.
Still no word on the V.2 of the 959 for $34.99? I mean it's able to pump over 400oz. without the need for a bec!? Might go ahead and pull it for the ol' lady's rig just for the hell of it and see what it's about, you know what they say.. If it sounds too good to be true, it probably is. The final product will be a PM S470, but not right now.
This is the newly upgraded version of Tower Pro MG959. The new PCB and IC control systems make it more accurate than previous versions.
Its internal gearing and motor are also upgraded to improve dead bandwidth and centering.
This version features a case machined from 6061 aluminum and comes with the heavy duty servo arm pictured.
These servos come from the original manufacturer of the Tower Pro servo line and we are an authorized reseller.
Don't be fooled by counterfeit, low quality servos being sold elsewhere.
Weight: 78g
Dimension: 40.2×20.1×36.8mm
Stall torque @ 6v: 444in/oz (32kg/cm)
Operating speed @ 6v: 0.13sec/60degree
Operating voltage: 4.8-6.0v
Temperature range: 0- 55deg
Plug: JR (Fits JR and Futaba)
Gear Type: Metal
Dead band width: 1us
Wire length: 32cm
Servo arms &screws included
CE &RoHS approved
Compatible with Futaba servo arm
Control system: +pulse width control 1520usec neutral
Required pulse: 3-5v peak to peak square wave
I have the Turnigy version sitting here waiting for my Gen7 to show up!
