Hydrocarbon92
I got received my first JX PDI-HV5932MG 30KG & JX PDI-6208MG 8kg (my faster vehicles) from AliExpress. The claims:
HV5932MG ($25)
Operating Speed: (6.0V) 0.12 sec/60
Operating Speed: (8.4V) 0.10 sec/60
Stall Torque: (6.0V) 25.2 kg.cm (350oz/in!!)
Stall Torque: (8.4V) 32.3 kg-cm (448.5 oz/in!!)
6208MG ($12)
Operating Speed (4.8V): 0.09 sec/60 degrees
Operating Speed (6V): 0.07 sec/60 degrees
Stall Torque (4.8V): 6.8 kg.cm (94.43 oz/in)
Stall Torque (6V): 8.2 kg.cm (113.88 oz/in)
Estimated @8.4v: 11.1 kg.cm (154.14 oz/in)
6221MG ($10)
Operating Speed (4.8V): 0.18 sec/60°
Operating Speed (6V): 0.16 sec/60°
Stall Torque (4.8V): 17.25 kg.cm (239.55oz/in)
Stall Torque (6V): 20.32 kg-cm (281.89 oz/in)
Estimated @8.4v: 27.44 kg.cm (381.07 oz/in)
I haven't received my digital luggage scale so I can't test power, but I can test speed. I wired up a direct 8.4v feed and the JX servos are fast. Their cheap 6221MG is faster than a Savox SC-0254MG (0.12sec) at 8.4v but a little slower at 6V, so I'm guessing a true 0.14sec at 6V and 0.11sec at 8.4v. Testing the new pair against the 6221MG made it look even slower than it made the Savox look, both at 6V and 8.4V. Either the HV5932MG is faster than rated or the 6208MG is slower, as they were the same speed. I also tested them against a TSX-45, a very common servo here and the 6221MG is the same speed at 6V but a LOT more power, so 8.4v will only improve it. The 6208MG is faster but seems to have similar power as the TSX45.
The only down sides: the 6221MG & 6208MG are a tad taller than normal & none are waterproof. However I conformal coat all my boards so that's not a big deal for me. If you don't like spending $80+ on servos or have a lot of models like me, I think these three are good choices - especially since they work on 8.4v.
HV5932MG ($25)
6208MG ($12)
6221MG ($10)
