Ty's RR10 Bomber Build
If you decide you want to run the VP trailing arms, my fix for the aluminum dragging was to make some skids. I took some .040 kydex( purchased from amazon) and traced the bottom of the trailing arm, and then used some heavy duty 3m double sided to hold the kydex to the trailing arm. So far so good. May need to revise them and use the shock bolt to hold the kydex in place, but so far this is working great.
Had these GMade PiggyBack XD 103s laying here since my Wraith is torn down. I think they will be at home on the Bomber! Also added de-anodized Axial trailing arm braces.
Hello,
I am trying to have the same setup as you had but the original gmade 103 spring is too soft for rear axle. Have you changed to the hard version?
I twisted the collar to the lowest point to maximise the compression but the chassis is still too low.
Thanks,
Rock
