Well...maybe...unless you want some real speed.
Having now run mine, I tried a 2S first with the 3300kv HH Trailmaster Pro and Mamba X set up so I didn't destroy it immediately, and was not impressed at all. I would consider it slow, comparable to my SCX10's on 3S.
Changing to a 3S helped (of course), but even with the high kv motor, stock diff gears and stock kit 12/64 pinion & spur, I really didn't consider it all that fast. I think my 2WD Slash is faster.
Seriously considering the two speed now.
:twisted::twisted::twisted: My motor is the Holmes Hobbies Puller Pro 540-L 4100kv "R-type" :twisted::twisted::twisted:
Running it on 3S only!
Keep in mind these are crawling motors for crawler trucks on a crawling forum.
20mph is already very fast for these solid axle trucks.
I know the puller pro XL can output serious speed in a yeti / rock rey.
More than that you have to go to the basher style rc cars like the slash, stampede, or any racing truck like the losi / associated or tekno truggy / buggy
Sent from my Nexus 6 using Tapatalk
I have underdrive front & rear to calm things down a bit...
20 mph is really an unrealistic "scale" top speed for a Bomber (160 mph @ 1:1, the wheelbase is too short to support that speed), 15 mph being more accurate (120 mph @ 1:1), do to reality that Bombers are actually 8th scale, not 10th. The problem with them not handling any speed is in part to the non-scale ~45 inch tall rock bouncer tires that come on it and that 99% of the owners run. Randy runs 37's in every pic I've seen, just like every other class 4400 rig that finishes well at events like the KOH, SCORE or BIDT, so its time to be stretching those 1.9s on your 2.2 wheels to keep true to the 1:1. I'll probably get so flaming for this statement, but......... a Bomber really isn't a really a crawler anyhow. Anyhow, no more distraction from this nice build.......
Durok, how about some updated assembled pics so I can drool over your $$$$$$$ rig? I'm guessing you're approaching the $1500 mark, right?
I just finished the transmission last night!
Had a job interview and some errands today, will be soldering a bit and building shocks this evening, and with any luck final assembly of the cage & setting up the electronics may happen during the holiday tomorrow.
My wheel and tire sets for this rig vary from 4.33" tall RC4WD Dune T/A 2.2" tires (they closely resemble the tires you see on Slawson's rig when he is out in the desert - basically trophy-truck ties) to the kit BFG Baja's (5.4") to massively oversized Team Losi Maxxis Creepy Crawlers (right about 5.8" tall) for when I am pretending that I have a scale rock bouncer...
I also have two 1.9" setups to try if I feel like banging up the SSD aluminum axle housings some more - RC4WD Ground Hawg II's on LURC Hutchinson Command ring-equipped TrailReadys and Vaterra Ascender TSL Super Swampers on some Injora alloys.
Finally, I have a set of tires that I can't get to mount up on my Incision Method MR307 beadlocks - they are some basher tires I picked up from Team DC, Nitto Mud Grappler copies, and their beads are too thin and a bit stretched out...
...so I may be purchasing CI plastic Double Deuce 6 Bolt glue-ons and some SLW hubs for them.
That leaves me with another "yet-unknown" tire option to mount on the Methods... I haven't decided what to get for them, I truly love my little 1.7" RC4WD Goodyear MT/Rs so much I may get a 2.2" set.
(Let's not forget that when this rig is finished, and I have driven it a time or two, I will need to begin on Bomber #2, which is going to be COMPLETELY different! So, these wheels and tires will be shared with that build)
