The "Just shut up and build it" thread...
One extreme to another:
$39.99 for all 4 (first set - Injora off-brand 1.9")
$195.99 for all 4 (second set - Locked Up RC 1.9" - includes all hardware, "TrailReady HD 8L" wheels, widening rings, "Command" beadlock rings)
I chose the "8L" style of LURC wheels partly because they require no hubs - they are one piece wheels/hex hubs (third pic, mounted inside RC4WD Interco Ground Hawg tire - below tire, left wheel is Injora and right is another unmounted LURC)
So much work! (last pic!)
Lucky you, i still can't belive they have 6 weeks of wait time for the M2 5mm scale bolts...
Enjoy the wrenching!
Sent from my Nexus 6 using Tapatalk
I don't have any on hand to test that out... but I'd say that scale hardware by nature of its size tends to cause problems.
My 1.7" RC4WD RaceLine beadlock wheel hex bolts and the LURC hex bolts both needed a gentle touch when tightening.
The end result is certainly a gorgeous piece of work, but I probably won't make a habit of building wheels like these in the future.
Sorry I’m so late with this, but thank you for your service! I have always looked up to those who have served, as I want to myself. Also, great lookin’ project! I want all of those parts!
Wow this is going to be an incredible build once you get going. Your parts list is awesome. And you will certainly have parts leftover to build others.
ATTENTION: Thread Title Acted Upon ! "thumbsup"
Saturday, 6/30/2018, nearly 2 years after the initial purchase date of my Axial Bomber kit from Tower Hobbies (7/26/2016 to be exact)...
I spent roughly 12 hours VERY slowly gathering together about half of my total parts purchased over that entire length of time and basically shut up and began to build it.
Parts used (so far!):
SSD Aluminum Diamond Axle housings (offset front, centered rear)
SSD HD centered rear axles (including Titanium rear hex hubs)
SSD Diamond Front Axle Upper Link Mount
SSD Skid for Diamond Axles (Delrin)
SSD HD D60 Knuckles
Vanquish Products AR60 Axle Servo Mount
Vanquish Products Servo Clamps
Vanquish Products Aluminum 12mm Hex Hubs (front axle)
Vanquish Knuckle Bushings (1 Pair)
Vanquish Products Wraith Scale C-Hubs
Incision Wraith VDI Universals
Incision 4mm Flanged Wheel Lock Nuts
LockedUp RC F1 Spools
Axial HD Underdriven F&R Differentials (43/13)
Axial Knuckle Bushings (1 pair)
SuperShafty / JEC Racing Bombproof Trailing Arms (Stainless Steel)
JEC Racing Stainless Steel Steering & Suspension Links (custom drilling)
Hot Racing Aluminum Axle Lower Shock Mounts
Traxxas Revo Rod Ends
Fast Eddy Bearings
Kyosho Shims
TrakPower Gear Grease
Gotta say the SSD HD centered axle shafts are very nice, as they are NOT drilled for hex hub pins. Instead they have flats machined on them and came with titanium hex hubs that have matching shapes machined out of their centers - axles and universals ALWAYS break where they are drilled... Shouldn't have to worry with this design!
I had to use Vanquish C-hubs because the Incision VDI universals have oversized joints and wouldn't fit the SSD Pro C-Hubs I originally purchased...
That's OK, I guess - it's just that I just wanted to use as much SSD hardware as possible on this rig, because I'm a fan. Ah, well...
I used Vanquish brass knuckle bushings, but they were a little too thick to use them top and bottom on each knuckle - so I used Axial black metal (steel?) bushings from the kit in the lower position (I tested with only the Axials and had tons of slop) and a very thin shim to get them totally snug...
Shimming the ring & pinion only required a .3mm shim in the rear and a .3mm plus a .1mm in the front, all under the pinion gear inside the diff housing. A little roughness was detected, but I'd rather break them in than run them loose.
Even though I did buy myself a little cordless bit-driver a while back, for this part I did it all by hand. It took me ages, but I was going about it pretty easy, taking frequent breaks. Got an errand to run later today for a few hours (been up ALL night - need to sleep some first!) and then I suppose it's shocks and the transmission.
As you can tell, I basically used nothing from the kit - this build will pretty much only use the cage and a couple minor things. OK, with that - I'm OUT!
Axle Porn:
Been trying for weeks to get a quote from JEC Racing but he always forgets...
I found it!
A quick question: the rod ends on the SuperShafty trailing arms are metal or plastic?
They use the best in the biz - Traxxas Revo rod-ends, nice and thick and strong.
The SuperShafty BombProof trailing arms are also available in 7075 aluminum as well as stainless steel - and slide over rocks in either material much better than common 6061 aluminum does:
https://supershafty.com/collections/axial-bomber-yeti-rr10/products/alloy-supershafty-bombproof-trailing-arms-yeti-score-bomber
OMG OMG OMG!!! Is this for real? is this happening? Is this some sort of Texas trickery?? :lmao:
Glad you finally got motivated!
Subbing as a future replacement parts list. "thumbsup"
Thanks a lot! Although I may need to wait for them, as for now they are sold out...
The stainless ones are sold out, but the 7075 (very hard!) aluminum ones are just as beefy - and if you check the various colors available you should be able to pick up a pair that's in stock.
They are identical, except for weight - and that can be a good thing, depending...
Also - if you HAVE to have the SS ones, you can reach out directly to JEC Racing on FaceBook, if you do that sort of thing - I got the rest of my links that way.
He will even custom engrave the trailing arms with words or even a cool logo if you ask nicely!
(Hope this helps!)
"thumbsup"
I dont know about Facebook but he is not answering much on messenger. Still waiting for my quote after more than a month and 3 reminders.
I might just have to grab the trailing arms from supershafty and the incision links...
Well I can wait... for now I have the originals and ordered some other aftermarket ones, until they last, I can drive...
Will keep one eye on these!
Moving on to the transmission:
Hot Racing - Aluminum housings, HD steel internal gears, motor mount
Axial - Top shaft, bottom shaft, output shaft
Fast Eddy Bearings
Pic:
I have this transmission setup - although I don't have extensive experience with them (this is the second I have assembled), I liked to spend time with it!
Are you doing 2 speed setup? If so, are you setting up a neutral too?
