TAT76
I've been thinking about building a yeti and your build is giving me the itch. Keep it coming.
I've not seen the pinout on this adapter, but that sounds right.I've spent the evening soldering (first time in 25 years!) and trying to get the wiring right, but I just can't figure it all out. This is what I've got:
ESC (Mamba X)
BEC
Rx bypass adapter
Y-harness with servo reverser
Steering servo
Servo for gearbox
BEC goes into the Rx bypass adapter, which in turn is connected to the steering servo and the receiver, right?
You don't need the battery connected for programming of the esc or bec.And then I use Castle link via the ESC to set the BEC output voltage, right again? Do I need to have a battery connected to program the ESC and BEC?
Sounds right.The Y harness has two female contacts, I guess the Aux wire goes into one and the gearbox servo goes into the other? The male then goes into Rx channel 3?
You would have already done this previously when you set the mamba's bec voltage, updated the firmware (if required), and set the aux wire for the rock racer/crawler mode switch.I then use Castle link to set the the aux wire to switch between rock racer and crawler mode as I change between second and first gear.
No, you connect the esc to the rx, then set the endpoints to engage/disengage the rock race/crawler mode to your liking, reversing the servo direction at the tx to get the switch working in the direction you want (up for high gear, down for low?) and then connect the servo using the (reversing) y-harness.... then if the servo does not move in the 'right' direction to engage the hi/lo gear to match the esc you then remove the (reversing) y-harness and put in a 'plain' y-harness.Should the servo be reversed, so that crawler mode is enabled in high gear, I just switch places of the aux-wire and servo contacts going into the Y harness/servo reverser?
I'd need to see the pinout on the connectors.Bypass adapter from steering servo then goes into rx channel 1?
yes.Brown-red-yellow wire from ESC goes into rx channel 2?
yes.Wire from Y-harness goes into rx channel 3?
yes.One slot (top one, called VCC) on rx is left empty?
I managed to get rx and castle bec and the spare wire into the fuel cell. I had to cut a larger horizontal slot to accommodate the wires and add some weatherstripping to keep the crap out.Please give me a helping hand, I feel rather lost.
On the slightly more practical side, where to stuff away all those wires? And where to put the on/off-switch?
Skickat från min SM-G920F via Tapatalk
correct "thumbsup"BEC goes into the Rx bypass adapter, which in turn is connected to the steering servo and the receiver, right?
no is powered by the usb port over castle linkDo I need to have a battery connected to program the ESC and BEC?
I don't recall burning myself so often when riding my bike....
you never forget how to solder if you have learned it once, like riding a bike:mrgreen:
Looks good. Use it as you have it labeled.Thanks a lot for helping me get this sorted! Seems as if I knew what to do (or rather just made some good guesses) , but didn't know that I knew, and then it's no real use knowing anyway.
Here's the Rx bypass and planned wiring to and from it.
I never fully submerse my cars but I find that snow can be just as bad, the way the snow clings to the relatively warm electronics, and the water still gets in there.I'll leave the BEC outside the rx-box and waterproof it by squirting some silicone into it. That ought to make it at the very least splash proof and that should be enough. I plan to drive Snowman as a car, not a submarine.
It's a GT3C, not a B, and that one needs a specific 800 mAh LiPo battery. Well, there are things to build while waiting, so it won't really delay finishing.
