new2rocks
Great build n2r I can't wait for mine to get here from rpp
Thanks! Notwithstanding some of the early production issues, I think you'll be very pleased.
Now that I've finished everything but the body, here are a few final notes from the build:
Clearance at the right knuckle between the drag link and tires is tight. The Gmade Steelies I'm using for now would rub if using the stock 4mm hexes:
RC4WD Raceline Monsters would clear, but not by much:
Back to the Gmade Steelies, a 6mm hex was enough to do the trick. So check the offset of the wheels you're planning to run and be prepared to toss on a wider hex if needed for clearance.
The rear springs may be a tad on the stiff side relative to the fronts for a stock setup. I have the shock collars all the way up in the back and the front collars cranked down a fair bit to get a relatively level ride height with the large 5200 mAh 3S pack strapped in. Adding weight in the form of metal bumpers, sliders, etc. would change this, of course. Just be ready for the possibility that you may want to play around with spring rates a bit.
That's it for the moment. More to come after guests leave and I can get in some run time. "thumbsup"
