hpiguy
That thread is more nerdy than this place.
Depends on what you consider nerdy I guess. I can find nerdy stuff on both sites, and I'm thankful for that. I think we all geek out on our hobbies in our own ways. "thumbsup"
Hpi I read through your thread on mtbr.
Couple of notes that I wanted to throw out there:
-The fork specs don't show a lock out setting. The adjustments on the fork are Air Pressure, LS Compression, Incremental Platform Adjust, Hydraulic Bottom Out,Rebound and I am sure you know this. In general fork function lock out is achieved when the lsc is closed off forcing the oil to go through the high speed compression circuit. The high speed circuit is managed by the shim stack. If the first "stage" of the stack, usually just the face shim with stock mtb forks is thick enough the fork will be locked out until it hits a big enough object where the force of the oil is strong enough to bend that shim. If the face shim is not strong enough to hold back the oil then you won't have lock out. Either way you can change the shims in the stack so you can have lock out. If you stick with the fork and are interested in shim tuning let me know, I can help with that and can send you shims to try out different tunes.
-did you try taking off the air valve either by removing the core or removing the whole air cap? That way you can measure how much travel the fork has and check for smoothness of travel manually without the air spring interfering.
-I have found that ALL fork manufactures don't ship their forks with the proper amount of oil in them. One of the first things I do when getting a new fork is to check the oil level on the dampener which is usually fine. Then drain and refill the splash/bath and float fluid. When checking the float fluid is when the air cap is removed and travel smoothness and travel are checked.
Jeff, I really appreaciate you taking the time to look at it. Once I actually get to ride one that works properly I'll know if the semi lockout will work for me or not. If it works the way it sounds like it will, then I think it will be fine. The only reason I'm concerned is that it's goiing on a SS. So I prefer to waste as little energy as possible moving a fork that should be propelling me forward instead. The lockout thing is 100% on me for not researching more.
I haven't torn into it as I don't have the Manitou tool kit, but if I keep the fork, I will order the tool kit for sure. At that point, I can verify overall travel, and I'll check the oil level as well.
Randy
