MaX-D
I reached out to CI and found out the inner foams really shouldn't be re-used
I'm moving from a 1" aluminum rim to a 1.5" plastic rim, and I don't want empty air space between the used foams and the new width of the tire
So I also asked them what they run in their bomber, and ordered a set. They recommended their rims, which are probably better built, but I preferred the axial versions
CWR 3303 rear
CWR 1305 front
New rims are axial part # AXI43006
Plastic beadlocks with 6 lug hubs, half off right now on AMain
Everything should be here this week, plan to run the same BFG baja's I have now![]()
Why did you decide to go with plastic beadlocks? Will you be using the stock hex hubs or Vanquish SLW? Just curious
