New to RC and addicted to crawling already (Running a Deadbolt)
dannyboyjdc
Ohio
New to this forum and RC's in general. First buy was a RS10xt for someone else... then I found a Deadbolt cheap at the LHS... I have now caught the mod addiction and work on it 10x the time I actually run it "thumbsup"
So Far I have done the basics, flipped shock mounts, moved battery up front, changed some mounting points for personal preference, 60T motor, etc.
When the snow started flying here in Ohio the snow chains were a must :mrgreen:
I have had a few repairs :oops: Ran it into the steps in the basement day one (it was way faster than I expected stock) and broke a shock and servo horn, so I am running aluminum Venom's with 30wt oil, new servo horn is on the way.
New servo is on the way with the new horn even though the stock one is still okay.
Next up is to get some weights on the axles just not sure how to go about it yet. Thinking about making a servo mount / axle support block from brass for a trick look (dad is a machinist so he would actually make it I would be there for moral support :twisted:). Maybe use the existing block as a mount for some plates if that is too tricky.
Then I want to upgrade the steering arms (just for looks it steers good enough for me). New c-hubs and knuckles as I suspect the weight may kill them.
Then it's time for cosmetics: Led lighting, Ford truck body, scale accessory packs, winch, and so many more when the wallet has some padding!!
Any suggestions are welcome though, I need all the help I can get and this forum has already helped SO much!!
Welcome to the forum! Browse through this section and you'll get an idea on what to upgrade, and the pictures thread for different body options. I usually upgrade parts when the stock ones break. Have fun and watch your wallet drain quickly!
Welcome,I'm a new guy that's addicted as well!!!!what servo are you gonna put on your deadbolt?I'm currently waiting for some goodies to upgrade my new Ridgecrest.
I am one of the cheapskates, just got a couple MG996 for starters/bashing ($7 ea.). I figure I can pass them on to the kiddo's RS10 when it eats the next servo. :razz:
Already have a wish list saved and ready to take to my LHS when I start breaking stuff "thumbsup"
Are there any stock parts left on there Norton? That thing is beast!! What tires are those?
I want to do a Ford super duty scaler as my next rig!!
The tires are Panther 5.4 Leopards and the only things left stock are the electronics box and the battery tray. LOL.
1st pic, when it was clean.
2nd pic, out bashing it.
If you are looking for new tires you can get beadlock wheels and use stick on lead weights inside the wheels so you don't see them. Can add or take out weight and change tires easily with the beadlocks. I have had up to 7oz weight in each front tire and haven't had issues with the stock c hubs or knuckles.
For sure the next big purchase will be aluminum bead locks and tires, from what I have read the additional weight has a HUGE impact on capability. I know from an ATV perspective tires are the #1 item for performance. Doesn't matter how much speed or torque if you can't get it to the ground and point it in the right direction.
Smoked the ESC running it in the snow today (about 6 inches deep)
It actually caught fire, so I think it is safe to throw it in the trash
Any suggestions on a waterproof replacement?
I am starting the thread combing now "thumbsup"
Not sure yet if I toasted the receiver or any other parts yet.
If i'm not mistaken the Sidewinder3 speed can be wired for a brushed motor. Dont quote me on this but, I believe you wire the 2 outer most wires to the brushed motor, and leave the middle wire off and insulate it off. However, the Holmes Hobbies BRXL Waterproof has a higher current and voltage BEC. As well as can run up to 6s lipo batteries. Where as the sidewinder3 only can handle up to 3s Lipo. As soon as my AE-2 speedo burns out in my Deadbolt I'll be replacing it with a H.H. BRXL."thumbsup"
Not quite up for the effort of Lipo's yet, just running for fun so NiMh is doing great (getting over an hour from 1 5000 Mah 7.2V with the Atomik 60T motor, little longer yet with the stock 20T).
Looks like I can get another AE-2 for about $40, or save up and get the HH around $110... Definitely want the HH and then look at higher voltage batteries, but don't wanna wait to scrounge up the dough. Off to ebay for in hopes of a cheap take off to hold me over!!!
Monty Python says "And now for something completely different"... Anyone run Lithium Ions? Are they just as maintenance heavy as LiPo?
Do NOT order from Robot Marketplace, I eventually got most of my stuff. Parts missing from bag, their site said in stock but they were out and they were in the midst of ordering for themselves before I canceled part of the order. Just get a brxl from holmes directly.
Yes the sidewinder can be programmed for brushed mode. Use a castlelink to program and omit the center white wire for the motor.
Thanks guys,
I think I have the $$ to go sidewinder and castle link or Holmes. I managed to sell an old ATV snow plow I had stashed in the garage "thumbsup"
So changed my mind again and went budget friendlier with a RC4wd Outcry with built in BEC. Seems like it had good reviews and will allow me to go higher cell Nimh as I am still really nervous about the Lipo batteries.
I really want to get some weight down low so some bead locks are next on my wish list.
So the Rc4wd Esc is working killer!!! :twisted: The brake is a bit intense, it pulls nosey's on every stop with the 20T motor and 14T pinion setup in (used this for snow and mud "thumbsup")
Getting the 60T back in soon...
but first have to take care of the next parts that failed :cry: :x the servo (i think I did this when I was trying to waterproof it :oops:). also managed to strip the transmission gears when it was in a bind.
Already had the new servo on the shelf, but I am not sure where to get new transmission gears (I want steel if possible) Any suggestions?
