themountain
I joined the Band!
Somebody told me that "stall protection" doesent do anything useful so I switched it off.Besides that I have the same settings...do you run a snubnose,Yudi ?
Yes, 2040kv snubnose.Somebody told me that "stall protection" doesent do anything so I switched it off.Besides that I have the same settings...do you run a snubnose,Yudi ?
And according to John in the video the stall protection "...is essentially like a semi rpm lock.... make a weaker motor felt like a lot stronger down low..."
No offense but he is a bit assuming there...but if he say so :roll:
EDIT: From the horses mouth :
"Alka Motors 12 hours ago
The stall protection is for crawlers and ground vehicle what it does is enforce minimum rpm. When the rpm drops below that level it will boost the throttle until rpm comes up to minimum again."
So I think I will switch it on again and see what is happening. 8)
Sweet...did you monitor temps on 4s? Pinion/Spur ?
BTW..what wheelbase is that car?
Can someone enlighten me on the KV/pole limitations they listed?
2200kv limit 14 pole (Revolver), 2500kv limit 10 pole (Revolver 10p), 2700kv limit 6 pole and 4 pole (Crawlmaster BL, 6 shooter and Puller Pro)
All of the current HH revolvers are 14 pole
I have a 2500KV (14pole) revolver, would this be over the limit? Im not sure if having more or less poles puts a motor over these limits?
Seems like maybe the less poles there are the higher the KV limit. Any insight would be appreciated
I don't know if I had too long of a day at work, or what... but my head is about to explode trying to understand how to update a crawlmaster mini.
I bought a PC to program mambas, so I have that stuff... what else do I need besides , to make these work on 4s?...
I’m running a full size 2500kv 10 pole with the crawlmaster mini, and the throttle is quite abrupt and hard to control. It does fine at very slow crawl, but is hard to control when you up the speed a bit.
I found 2500kv to be a bit too fast on 4s even when I geared it down a ton, I switched to a 1000KV which was a better match for my setup.
Have you played around with the programming? Did you also update to 1.2? (update link is on the product page at the bottom)
https://www.youtube.com/watch?v=Hkc78rt1Oic
<iframe width="560" height="315" src="https://www.youtube.com/embed/Hkc78rt1Oic" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
I found the Sinisoidal startup annoying, sure it will start up slower but there is a harsh transition from low to higher speed. I just found it better to avoid that transition YMMV.
You might also play around with the startup power too. I tried to adjust startup power to work better with Sinusoidal startup but couldn't find a better setup than just turning off sinusoidal startup.
