I have a 2300 on the way. I bought a stubby kit for my Carbon a couple months ago when I saw your teasers about this motor. If you do manage to 2 in 1 these at some point, it would be great if they were 4s capable.
Hmm if I'm reading between the lines correctly maybe just maybe there could be a 2 in 1 version. <-- Just for anyone else as thick as me who didn't pick up on it at first lol
Thanks 89Industries!
Several of the AM32 ESCs are the same board...Dlux, Silent Assassin, Exo Belay, and the Stilte to name a few. They vary a good bit in price and some are conformal coated. Some of those have a BEC but it is not adequate for a high torque servo. The CMV3 is a 40A Rhino built to Holmes specs.Thinking of getting this motor to run in the H10 Origin.
What ESC would be the best? Would like to have it water proof.
Holmes CMV3 and conformal coat the shit out of it?
Or is there maybe a better option that would be water proof?
Great Info. Thanks. And I have 2 Reefs for the kit when it gets here already. A Triple 8 4s direct power servo and an IS:800 winch servo if I want to add winch to it, which I probably will. so the BEC will only need to power the winch and maybe lights, But I could just BEC those and run a bypass loom.Several of the AM32 ESCs are the same board...Dlux, Silent Assassin, Exo Belay, and the Stilte to name a few. They vary a good bit in price and some are conformal coated. Some of those have a BEC but it is not adequate for a high torque servo. The CMV3 is a 40A Rhino built to Holmes specs.
I'm running an 80 amp Rhino in one rig and an Exo Belay in another. The Belay is smaller and lighter, even with an external BEC. It has a random quirk where it does not power up properly and needs to be unplugged and plugged back in. Other than that, it works fine. The Rhino is about a year and a half old and it has been submerged on more than one occasion. Its kinda chunky but other than that, I like it. Reefs servos have a disclaimer to not use Rhino electronics with their servos though. Not sure exactly why. I've been using their winch with it the whole time, plus about 8 months on another truck.
I have some Team Brood Conformal already.You can also buy a little bottle of conformal coating and waterproof it yourself. Its pretty easy, brush it on and let it dry. Just make sure you're done with all the soldering (if needed) on the board first. Team brood sells it as do others I would assume.
Search for: conformal coating - AMain Hobbies
I will only release products that are 4s capable at this point![]()
