themountain
I joined the Band!
Nothing....still there :mrgreen:@themountain, what happened with the wiki?
https://github.com/AlkaMotors/AM32-MultiRotor-ESC-firmware/wiki/ESC-Settings-Explained
What firmware do you use ??Hello, anybody used 4s with this firmware?
I am experiencing overheating
I am using Skystar 50a and Aikon 45a with Iflight50 firmware, getting hot quickly, and activate the ESC thermal cutoff in less than 5 minute of indoor running
Sent from my SM-A515F using Tapatalk
Iflight50 1.80What firmware do you use ??
What does best mean?
Sent from my SM-N986U using Tapatalk
I purchased a preprogrammed Wraith32 ESC. Turns out that the motor won't arm when paired with my Sanwa radio. The motor beeps then responds only to reverse briefly then after that no response at all forward or reverse. I've toyed with the neutral range without any success and also attempted to adjust radio settings in case there was an issue there. I'm stumped as to what might be different about the Sanwa neutral signal or what else might be preventing the motor from arming properly. (battery good, connections good, wiring correct, etc) If anyone has a suggestion as to where else I might look, I'd appreciate the feedback.
Version 1.85
(In the mean time, I'll be connecting the ESC to a friends FlySky radio to ensure that the ESC was properly programmed etc. I also have ESC's on order from RTFQ for programming that I'll be doing myself.)
Be part of the slack AM32 group ...lots of folks had flashed that esc ...somebody certainly can point you in the right direction"thumbsup"Basically I can connectread the ESC but I can't flash/upload anything to the esc... I have 2 of them and the act the same.
Well if it's not a stm chip why would it work with stcube? Am32 also needs to have the programming for the chip. Which it probably doesn't. But there have been more chips added recently. I haven't been following close though. These questions are better asked in am32 slack chat where Alka will respond.hi, the question is more about Voodoo, in general, I ordered a TEKKO f4 45a controller (a copy of Wraith32), a chip not STM32 but at32f421k8u7, stcube cannot interact with it....what about that?
