Little Bushido, looks like it's a 1.55er?
Super, the body is designed for large tires. Magic!It on their website now. States tires are 1.9x4.65
https://www.associatedelectrics.com/element/cars_and_trucks/Enduro/Bushido_Trail_Truck/
Nice "thumbsup" 11.8" wheelbase will be much easier to build around than the Proline Sumo (10") which is discontinued now.
picked up a Barrage kit long ago, not sure if I find it to my liking - a bit too flexible.
I still have one of those bodies, untouched so far...
Can't decide what to mount it on - picked up a Barrage kit long ago, not sure if I find it to my liking - a bit too flexible.[/QUOTE=durok;6123777]
Are you familiar with the "Zukosaurus" chassis created by a member on this forum (Utieh)? He designed a set of rails specifically for the Pro-Line Sumo body which utilizes SCX10-II parts - so it's a very simple build with extremely common parts. I bet you could use some Element parts as well.
My first RC Crawler was a Barrage, and I was going to mount a Sumo body on the Barrage chassis, but I abandoned that idea after building a Zukosaurus chassis. So much more capable than a Barrage. I now have two of them - one with a Sumo body, and the other with a Tamiya early Bronco body.
That said, I am definitely interested in the Bushido. I will be looking forward to seeing one in person at PLBTF this weekend.
https://radrocks.bigcartel.com/product/zukosaurus-short-wheelbase-scale-chassis
Thanks for that link!
Unfortunately, sold out...
I'll reach out to see if more are planned - I definitely have the spares to build one up - I'd likely use my SSD axles and Element skid/trans.
Over thinking again lol.The new Element Enduro Bushido Trail Truck RTR 1/10 "thumbsup"
* Injection-molded mirrors, grill, wipers, snorkel, bumpers, and rear bed cage
* Licensed 1.9″ x 4.65″ General Grabber X3 tires
* Element RC Ocho beadlock wheels
* Replaceable headlight lenses
* Adjustable front and rear injection-molded bumpers
* Wheelbase – 11.8″ (299mm)
Price: $399.99
Pre-Order at Amain
Reedy Power electronics. The ultra-smooth, and powerful 16-turn, 5-slot brushed crawler motor and Reedy Power SC480X electronic speed controller with T-plug connector supply ample power to this tough rig. Controlling the beast on the trail is the 3-channel XP130 2.4GHz radio and Reedy Power high-torque 1523MG metal-gear servo 15kg Waterproof
Features:
Electronics:
Reedy 5-Slot 16-Turn High Torque motor
Reedy Power high-torque 1523MG metal gear servo
Servo pushing out 208oz-in (15kg-cm) of torque at 6V Waterproof !
XP130 2.4GHz 3-Channel Transmitter and Receiver
Body:
Bushido 1-piece body thermoformed in high-strength polycarbonate
Clear windows
Molded grille
Injection-molded snorkel, wipers, and mirrors
Realistic styling
Injection-molded rear bed cage
Chassis:
BTA (behind the axle) steering
Aluminum steering plates
Integrated servo winch mount
Threaded aluminum shock bodies
Stealth X gearbox with adjustable overdrive gears
CMS (Chassis Mounted Servo)
Adjustable front track bar
Universal front drive axles
Stamped steel frame rails
Enclosed receiver box
12mm wheel hexes
Adjustable front and rear bumper mounts
Adjustable width rock sliders
Two battery boxes
Aluminum motor plate
Adjustable body posts
Optimized ball cups for more fluid axle articulation
Adjustable rear shock tower mount positions
Telescopic driveshafts front and rear
Extruded aluminum driveshaft splines
One-piece rear axle design
Splined front axle with adjustable caster
Machined input pinion gear
Specifications:
Scale: 1:10
Power: Electric
Length: 462mm
Width: 236mm
Weight: varies
Wheelbase: 300mm (11.8”)
Axle Ratio: 3.75:1
Completion Level: Ready-to-Run
Includes:
(1) Enduro Bushido Trail Truck 4X4 RTR 1/10 Rock Crawler with:
Extra Decal Sheets
Reedy Compact Balance Charger (ASC27201)
Reedy LiPo battery (ASC758)
Looks great.
Question 1:
That stock 5 slot 16t motor is 540 size right?
Then it needs 3s if it is 540. 550 Can be ok at 2s, not 540 i believe.
Second question
Will the ESC handle 3s ?`
RTR no Lipo, no Charger 399us
RTR Lipo Combo with charger 369-379us
Despite the massive flex the Barrage can work well, I think people often put too much stock in being absolutely rigid. The original SCX10 was a bit of a wet noodle but it worked.
this guy is big i dident get up close but its no 10th scale
