I have to ask, have you seen these wheels and tires?
Would you really trust a 12mm hex with this behemoth.
Where are you gonna find a 7" tall 2.2" tire?
Honestly I dont see 2.2's as an option for this thing.
Here's a comparison vs Axial KR2's from the Bomber
Funny how you ask would you REALLY trust a 12mm hex? APPARENTLY, the losi LMT can use 12mm hexes, so you can use other wheels with the monster truck.
And that is a monster truck.
Think someone besides Vitavon will drop aluminum beadlock wheels for this that will work with the SLW hub?
s
I'm half-tempted to scoop up a set of the wheels and tires and install them on my Team Associated DB8 Nomad 1/8th scale buggy, it is a belly dragger as is.
That said, too much flex can affect performance. One area the SCX6 is lacking is steering and it's not entirely attributed to the servo. The panhard end connection mounts are plastic and are single shear so a lot of steering throw is lost to flex in these plastic mounts. This guy has braced both ends of the panhard mounts to regain some lost throw. This is something I can do myself and it's free.
https://www.youtube.com/watch?v=QKTXlO_wKnw
I didn't notice how much it flexed until I read this and check mine out. I was shocked at all the flex. Its a bummer that they copied the original panhard mount instead of making it a double shear. Oh well gonna try and make my own braces to see if it helps. Already did the bec which did make a difference.
you really should. I mean, why not? it sounds like a fun and easy way to refresh a rig
