The specs page on the website lists no change in wheelbase, length, or height
Technically, there's three "versions" of the Capra: the original RTR, the kit (based on the original), and the new 4WS RTR. Between the three, I prefer the kit, and you can build (and paint) it however you want...plus, you can install whatever electronics you want, such as going brushless (both RTRs only include brushed).If I was looking at a new Capra and my first 1/10 scale rig, between the two versions is there one that would be recommended over the other?
What I don't get...and, I'm thinking a lot of others don't get...is why Axial didn't set up the 4WS Capra the same way. Instead of using the toggle switch for setting the rear into these 5 pre-programmed positions (which ISN'T "steering"), they could have set the toggle for switching between the 4 above-mentioned steering modes. It's fantastic that Axial took notice of all the 4WS converted Capra, and decided to release an RTR with 4WS...but, as far as I'm concerned, the implementation of that 4WS is a 'FAIL'.
Understood...and agreed. Between the 'traditional' compromise, and the one axial decided to take, I prefer the 'traditional'. With my first C3 rig, that is the direction I went with. Sweet, there is a fourth opt ion, which 'one-ups' the traditional method - using a second switch on the Tx, setting the rear servo's endpoints at 50%, and setting the rear servo's speed to 50%. The ability to still have the 4WS modes, while also giving the user the ability to select rear steering identical to, as well as 50% of, the front.Anything short of fully proportional, independent control of the front and rear steering is a compromise. Channel mixing and multi point setups are both flawed methods, it’s just a matter of which compromise you prefer.
I don't see any innovation here with this "new" offering.
I agree. It would more than likely cost over that to convert a regular capra to 4WS.For the extra $50 axial is asking for, its seems like a good deal to me. If this was out in a kit when i bought mine, it would have been a no brainer.
______________________________________
AR60 VS410
TRX4 Sport
coming soon..
Veterans deserve a whole month too...
I've watched a few videos, and, based on what I think I'm seeing, now I really don't like this new Capra. The rear "steering" isn't really steering...at least, not accurately, or in the traditional sense. Worse, not only does the percentage not correlate to the front steering...but, it also appears to be completely independent of the front. It uses a 'toggle' switch for controlling the rear, of which there are 5 pre-programmed positions: 100% left, 50% left, centered, 50% right, 100% right.
When I built my first 4WS rig (a Capra, of which the only Axial parts were the cage, and the only other Capra parts being a 3D-printed skid (for AX10-style 3-gear trans), and the CF & aluminum body panels), it was done in the way (pretty much) everyone else does their 4WS setups - with the rear steering equal to the front, and the four traditional modes (front only, rear only, opposite, and crab walk).
~ More peace, love, and kindness would make the world a much better place
What is remiss is that they didn't package this RTR with a 4-channel radio so you could also use the DIG out of the box.
^^This^^
For trail crawling, it *could* be useful. But, when it comes to competition (Class 3, which is the ONLY class allowing the use of 4WS & dig), you can only use one, OR the other. It's ok to have a vehicle with both...but, if you get caught using both (at the same time, as well as at different times), then you WILL be eliminated. It's for this reason that I have one Class 3 rig with 4WS, and am in the process of building a second with dig.I'm no expert, but wonder if the dig is even needed if u have 4-wheel steering??
Actually, dig HELPS make turns tighter. With 2WS & dig, you can almost "turn on a dime". With 2WS & dig, I'd be willing to guess it *would* "turn on a dime".It would potentially negate a lot of the front drag/tight turn benefit certainly, however a DIG is still useful on really steep descents as a rear axle drag-brake to help stop the rear end overtaking the front and flipping forwards.
