Good morning Ben, thanks I'm mostly working on the K10 and just wheeling/loaning the K5 Blazer, since the Blazer just flat out works. At MRB Fire and Ice, I drove the K10 (Rockhugger drove the Va'Blazer) I try to only disassemble one truck at a time so that I always have at least one crawler ready to go at a moments notice. All the current mods are being done to the K10, it's currently set at WB2, but with WB4 rear links resulting in a modified WB3. K10 has sideways steering servo mounted to top of servo mounts, Blazer has fore/aft mounted servo below the mounts in stock location.
The aluminum shocks are a little smoother than stock plastic, stronger and look nice. I've not had any problems with the Vaterra plastic shocks, but I've had other brands of plastic shocks rip the cap off and break the plastic upper mounting loop off. I've mentioned the upper mount to Vaterra. There's no fabrication, I like to tinker and improve things when possible, therefore I tried a bunch of different upper mount methods to see which I like best. In the end I used some spare Vaterra ball ends I already had, but could have popped them out of the plastic shocks for zero cost. Thanks, I'm working on my take of the K10 on WB4!
