Natedog
Not yet, I'll definitely update you if and when I do.
Usually I like them limited 9mm internally on Ascender for my driving style and terrain. K10 is going more extreme crawler so I wanted little more flex, hence only 6mm limited. I also like outboard at axle only. Shocks leaning forward softens the effective spring rate and the rear will tend to tuck under and back flip on steep climbs. Stand them up like stock or run stiffer upper and lower springs or single stiff spring. Leaned forward may need little thicker shock oil or smaller piston holes too, depending on how you like it damped.
