Ok magic swaybar numbers for me are 20mm back from factory hole and 5mm down from top of frame rail. Swaybar is in and working. Made 90mm long bar (same length as Wraith rear bar, but mine is 0.072" diameter piano wire with flats ground on both ends. To set spacing between bar arm and frame, I used plastic black nut from Axial shock plastic tree I had leftover. End links are 35mm eye to eye and made with 30mm setscrews and shock ends.
